Canon 5570 Won't power on
  • aosman
    • Aug 2025
    [Electrical] Canon 5570 Won't power on
    Hello. This machine has been tripping fuser codes for a while. I would reset the breaker and reset the code and it would work for a while. Yes, the fuser has been redone with all OEM sensors and rollers. I told the customer numerous times that they need a dedicated power line. I believe what they were using is being drained by another Canon 5070 on the same circuit, plus other printers. Their solution was to run a long extension cable to another outlet. Now I can't get it to turn on period. If there is no pwer to the unit, I can reset the breaker to the on position, but as soon as you feed power it trips to off. I admit I am not the strongest with electrical issues, but I am leaning to replacement of the breaker unit, because of the power fluctuation on that circuit. Maybe it dmaged the breaker.
    So, I am asking for your opinions. Please help. Thanks, so much.
  • ikon01
    • Apr 2011
    • 53
    Re: Canon 5570 Won't power on
    I'd start back tracking.what fuser codes are you getting?when did the codes start and did they start after any work?
    It's unlikly to be a faulty breaker.you may want to consider swopping out the upper fixing assy complete,lfr and bearings.
    I've had plenty of problems with them.
    • aosman
      What if I put the entire Fixing frame from one copier to another? One is a 5570 and the other is a 5070.
      But that still doesn't solve why it won't power up. I know the power supply is good.
      • adhy
        • Feb 2011
        • 109
        what indicates on control panel is it pilot lamp is ON?
        • songela
          • Mar 2008
          • 216
          Try to make a distinction between 1. Power tripping and Fuser error codes. If there are any Error Codes, please mention them (eg E00001-0002).
          2. The Circuit Breaker andthe Power Switch, the power switch can also trip by action of its auto shut-off circiut.
          As well try this, Open the front door cover and switch ON the machine with unit 1 out. Wait for a while, if the power does not trip, re-insert the unit 1. IF the tripping occurrs, then you can associate it to a faulty unit 1. Inspect the connectors at the rear of unit 1, especially the heater connectors.
