I tried to load envelop into canon ir257oci but i have problem loading and as well as printing . can anyone help me with the settings
urgent reply
thank you
urgent reply
thank you
here is the answer again. please explain what you have tried to do !!!!! ------------------------------------------
Envelopes should be fed out Cassette 1 if using Envelope Feeder Attachment-C1
Envelopes can be loaded into paper drawer 1 onlyif the optional Envelope Feeder Attachment-C1 is attached-
Envelopes in> Stack Bypass/Manual Feed tray> can be used if u don't have attachment
Envelope sizes accepted -
ISO-B5:- 7" x 9 7/8" (176 mm x 250 mm)
ISO-C5:- 6 3/8" x 9" (162 mm x 229 mm)
COM 10:- 4 1/8" x 9 1/2" (104.7 mm x 241.3 mm)
Monarch:- 3 7/8" x 7 1/2" (98.4 mm x 190.5 mm)
DL:- 4 3/8" x 8 5/8" (110 mm x 220 mm)
Yougata 4:- 4 1/8" x 9 1/4" (105 mm x 235 mm)
BYPASS TRAY
โข If you are printing on envelopes, do not allow more than 10 envelopes to accumulate in the output tray. Always empty the output tray once 10 envelopes have accumulated.
โข If you select [Envelope] for copying or printing, you cannot use the Multi-Page Enlargement, Collate, 1 2-Sided, 2 2-Sided, Book 2-Sided, Two-page Separation,
Cover/Sheet Insertion, Image Combination, Booklet, or Transparency Interleaving mode.
IMPORTANT==
If the envelope type is not selected correctly, a paper jam will occur.
If you select [Envelope] when printing documents stored in an inbox, you cannot use the Collate,Two-sided, Cover/Sheet Insertion, or Booklet mode.
