having problem print envelop
  • fatove
    I tried to load envelop into canon ir257oci but i have problem loading and as well as printing . can anyone help me with the settings
    urgent reply
    thank you
  • Van Steal
    • 177
    Re: having problem print envelop
    Teckat has already given you the info you req in your last a equally vague post. Read it and THANK him
      • 16083
      urgent reply
      thank you
      see this>> click on linkback >for complete instructions I posted> that is it
      http://www.copytechnet.com/forums/ca...ng-evelop.html
        • 16083
        here is the answer again.
        please explain what you have tried to do !!!!!
        Envelopes should be fed out Cassette 1 if using Envelope Feeder Attachment-C1
        Envelopes can be loaded into paper drawer 1 only if the optional Envelope Feeder Attachment-C1 is attached-
        Envelopes in>
        Stack Bypass/Manual Feed tray> can be used if u don't have attachment
        Envelope sizes accepted -
        ISO-B5:- 7" x 9 7/8" (176 mm x 250 mm)
        ISO-C5:- 6 3/8" x 9" (162 mm x 229 mm)
        COM 10:- 4 1/8" x 9 1/2" (104.7 mm x 241.3 mm)
        Monarch:- 3 7/8" x 7 1/2" (98.4 mm x 190.5 mm)
        DL:- 4 3/8" x 8 5/8" (110 mm x 220 mm)
        Yougata 4:- 4 1/8" x 9 1/4" (105 mm x 235 mm)
        BYPASS TRAY
        • If you are printing on envelopes, do not allow more than 10 envelopes to accumulate in the output tray. Always empty the output tray once 10 envelopes have accumulated.
        • If you select [Envelope] for copying or printing, you cannot use the Multi-Page Enlargement, Collate, 1 2-Sided, 2 2-Sided, Book 2-Sided, Two-page Separation,
        Cover/Sheet Insertion, Image Combination, Booklet, or Transparency Interleaving mode.
        IMPORTANT==
        If the envelope type is not selected correctly, a paper jam will occur.
        If you select [Envelope] when printing documents stored in an inbox, you cannot use the Collate,Two-sided, Cover/Sheet Insertion, or Booklet mode.
