E197 canon IR1018 !!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] E197 canon IR1018 !!!!
    after i cleaned canon IR1018 it make E197 , i checked printer engine communication and connectors of DC controller PCB and image processor PCB , but no happend::!!! i replaced the image processor PCB in another machine but same problem!!! E197 can any one help me!!
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • gensys
    • Jan 2011
    • 323
    Re: E197 canon IR1018 !!!!
    E197 0000 Printer engine communication error
    Erroneous communication between the DC controller PCB and
    image processor PCB was detected.
    >>>>> Check the connectors of the DC controller PCB and image
    processor PCB.
    - Replace the DC controller PCB for normal connection.
    - Replace or check CCD unite.
    - Replace the image processor PCB.
    Also checked with known good parts:- Memory Dimm, Relay Board , Flat Cable , Cable (FM2-4921-000) Normal machine rotations did not occur during the machine boot sequence, nor did scanner initialization.
    ..............>>> : The voltages on the Power Supply Unit (FK2-1376-000) were also checked and it was found that the 24V that should be present on the connection cable between J103 on the DC Controller & J14 on the Power supply was missing at pins 1, 3 & 6 on J14. Replacing the Power Supply Unit immediately resolved the error code.
    Remark .............. Incidentally if either the connection ‘Cable’ (FM2-4921-000) between DC Controller (J103) & Power Supply Unit (J14) is removed or the ‘Flat Cable’ (FK2-1395-000) between DC Controller (J104) & Image Processor PCB (J314) the E-197 error code is generated. This means that faults in either cable will give error E-197.
    The Road will be Mastered by >>> the Going...
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      Is there any idea !! i replaced the same DC controller PCB in another IR1018 but it shows the same Error E197 !
      what can i do to resolve this problem!!!!!
      DAMENE ABDEL AZIZ
      DJELFA
      • charm5496
        • 2387
        Error :
        E197 at Power On
        Workaround :
        In this case a faulty Ribbon Cable between the DC Controller and the Image Processor was found. The Ribbon Cable plugs into the DC Controller at Connector J207. Replacing the Ribbon Cable, part number FK2-1059-000, resolved the issue.
        Error :
        Error code E197 is occurring.
        Workaround :
        In this example, performing a #CLEAR > ALL in service mode corrected the problem.
        • wild boy
          • Oct 2010
          • 2
          Try to replace FM2-8363-010 Reader controller PCB ASSY
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            Drea Friends
            I took all the possibilities, i replaced the DC CONTROLLER PCB in another machine but have the same err!!! that's my prblm !
            DAMENE ABDEL AZIZ
            DJELFA
            • teckat
              • 16083
              Connector issue
              • charm5496
                • 2387
                Drea Friends
                Take the time to read the responses given to you please!!!
                Error :
                E197 at Power On
                Workaround :
                Error :
                Workaround :
                • HELIO240
                  • Jan 2011
                  • 137
                  Drea Friends
                  e197 this error can be caused by various reasons.
                  contacts pcb dc controler dirty in the part of HVT.
                  toner below the developer unit.
                  Contact the developer unit dirty or bad.
                  pcb supply problems.
                  dc controler problems.
                  flat dc controler problems.
                  Before replacing any item as a PCBS clear all the machine.
                  The main reason for this error and toner fallen debris inside the machine, clean the machine forever.
                  • sweet.persona
                    Engineer
                    • Nov 2009
                    • 414
                    Hello firstly
                    i am okay with u in this idea dude but pleas read my thread well !
                    i replaced the DC CONTROLLER PCB in another machine ( New machine ) but also the news machine Showed the same Error !! so this Error it is in the DC CONTROLLER PCB !! Means that the problem is specific in the DC CONTROLLER!
                    DAMENE ABDEL AZIZ
                    DJELFA
                    • HELIO240
                      • Jan 2011
                      • 137
                      Hello firstly
                      hello,
                      Sorry did not see that you had mentioned that the defect came to another machine. Damn PCBs canon.
                      • teckat
                        • 16083
                        get another DC PCB
