IR3025 Blank screen
  • LennoxD
    • Sep 2011
    • 82
    IR3025 Blank screen
    Black screen. no boot up when power on but power LED is light on control panel. Any suggestion
  • teckat
    • 16083
    Re: IR3025 Blank screen
    controller power supplyFM2-2764-000
    When you turn on the machine there is no power up sequence, no LCD display, and the control panel Green LED is on. The All-Night Power Supply protection circuit may be shutting off power to all loads. The RMT1 and RMT2 signals are used to trigger the protection circuit and disable the power supplies.
    SEE>>>>No Power-No Display-CP LED On RMT1 Checks.doc
    • wellrajive
      • Oct 2013
      • 31
      solution is here..
      • copier tech
        • 8133
        When a Canon doesn't boot up its usually bad ram. Try cleaning the contacts but use a solvent not your fingers as in that YouTube video!
        • Brian8506
          • 1664
          A friend had the same problem the other day and it was a loose connector on the main controller so don't rule out the easy ones.
