imagePRESS C1 / imagePRESS C1 Printer / imagePRESS C1+/Stained Image
  • teckat
    • 16083
    [CQ] imagePRESS C1 / imagePRESS C1 Printer / imagePRESS C1+/Stained Image
    Countermeasure for a Stained Image Caused by Worn De-curler Feed Rollers
    Upper Feed Roller (FC7-1127-000 ) and Lower Feed Roller (FC7-1155-000) become worn out
    where they contact the Support Roller . The powder generated by the abrasion adheres to the Upper Feed
    Roller and Lower Feed Roller as well as the Sponge Roller . The powder is then transferred to the
    media and results in a stained image to the output print.
    see pdf>>>>iPRC Decurler Feed Rollers-TP11-1.pdf
  • gensys
    • Jan 2011
    • 323
    Re: imagePRESS C1 / imagePRESS C1 Printer / imagePRESS C1+/Stained Image
    see pdf>>>>[ATTACH]12596[/ATTACH]
    Thanks!!!!!!!!!!!!
    The Road will be Mastered by >>> the Going...
