Imagerunner 9060pro
  • jorm
    • Feb 2011
    • 9
    [CQ] Imagerunner 9060pro
    Dear sirs
    Would like to know your opinion on this auto gradation test if it is normal.
    1 should the lowest 5 rows be totally white
    2 the grey center is veru moisy is that normal
    This is done on Canon 105gr High grade paper.
    Best regards
    jorm
  • teckat
    • 16083
    Re: Imagerunner 9060pro
    Test Print
    For automatic gradation correction, test print is performed to 4 sheets. Dmax-Pascal control
    is performed, using 1 out of these 4 sheets.
    what does your MCYBk Horizontal Line (TYPE=10)
    print look like ??????
    NORMAL=
    PG12-14 ???? check them-
    • jorm
      • Feb 2011
      • 9
      Picture you have attached is something im looking for in my machine, what could be wrong in my machine?
      Why is my tests so bad?
      I have done test with all four sheets but all the same.
      jorm
      Originally posted by teckat
      Test Print
      [ATTACH=CONFIG]12655[/ATTACH]
      • teckat
        • 16083
        jorm
        your Gray Scale is off
        did u run those test prints I posted ???
        PG10-PG12-PG14 ????? to inspect
        • jorm
          • Feb 2011
          • 9
          Sorry for my knowledge in this, but how are these tests done'
          Jorm
          • charm5496
            • 2387
            service mode>copier>test>PG input your test page number in PG-TYPE and choose OK. Go to page 2 and choose your drawer selection and quantity hit ok for both and then hit your start button.
            I would highly recommend getting a manual for this machine. Also when in service mode there is a green button at the bottom of the screen which gives you a description of the test mode menu.
            • jorm
              • Feb 2011
              • 9
              Found out how this is done, here are the tests
              • charm5496
                • 2387
                so do you still have concerns with the quality of this machine? Did the colors and grey output improve after running the auto gradation?
                Is your paper type set correctly? Are the drums, developer and ITB in good condition?
                The first auto gradation page you ran looks normal with the white space.
                • jorm
                  • Feb 2011
                  • 9
                  When you say paper type set correctly? can you give me a little more description, ( i just choose plain 2 because i have 100gr paper)
                  jorm
                  • charm5496
                    • 2387
                    that is correct.
                    Also has the ITB upgrade kit been installed along with the latest firmware release?
                    • teckat
                      • 16083
                      Jorm
                      Calibration iRADVANCE C SERIES PDF's/ LINK BACK___below
                      http://www.copytechnet.com/forums/ca...t-revised.html
