Irc5185
+ More Options
Posts
  • copicatt
    • Nov 2008
    • 366
    [CQ] Irc5185
    Customer has been using another service provider but they have parted ways. Wants me to check out this machine. Dont do alot of color, but some. The prints seem too bold, which is causing some shadowing around images/ text. Copying looks ok. Never calibrated a fiery and wandering ifi can use grayscale chart. Have read up somewhat about how to do it under printer screen. Anyy pointers? Thanks!!
  • KL568
    _
    • Feb 2011
    • 324
    Re: Irc5185
    Possible to post samples of the shadowing text? I might be wrong but if using PCL printer driver, try to look for a settings known as "Gray compensation" to enable.
    Which Fiery is it attached with? H1 (rear-mounted) or the GX100 (External tower-based)
    • copicatt
      • Nov 2008
      • 366
      Its an h1. Dont notice it so much today. I am onsite, the biggest problem now is that the image is bleeding toward trailing edge, heavy stock 11x17. LTR is fine. More like smearing or dragging. Actually ink looking......
      • KL568
        _
        • Feb 2011
        • 324
        Re: Irc5185
        Ok, then drop my suggestion of gray compensation. Since it print on heavy stock, has the printer's settings for heavy paper specific before you submit the print jobs?
        • copicatt
          • Nov 2008
          • 366
          Yes, it is chosen when loading the paper in the bypass tray. Then the job is sent. Took apart and cleaned itb rollers, seemed to help....thx
          • charm5496
            • 2387
            Re: Irc5185
            is it smearing on 11x17 plain stock?
            Could be ITB guides, cleaner blade failing, heavy paper kicking up when passing the fuser into the vertical feed path.
            What are the specs on the paper?
