Customer has been using another service provider but they have parted ways. Wants me to check out this machine. Dont do alot of color, but some. The prints seem too bold, which is causing some shadowing around images/ text. Copying looks ok. Never calibrated a fiery and wandering ifi can use grayscale chart. Have read up somewhat about how to do it under printer screen. Anyy pointers? Thanks!!
Irc5185
Re: Irc5185
Ok, then drop my suggestion of gray compensation. Since it print on heavy stock, has the printer's settings for heavy paper specific before you submit the print jobs?Comment
Re: Irc5185
is it smearing on 11x17 plain stock?
Could be ITB guides, cleaner blade failing, heavy paper kicking up when passing the fuser into the vertical feed path.
What are the specs on the paper?Accidents don't just happen. They must be carelessly planned.Comment
