IR7200 replace laser assembly
  • madu132
    • Dec 2008
    • 65
    I want to replace laser assembly on IR7200.
    In SM, it said to adjust the LA-DELAY after replacement.
    Where can I found this LA-DELAY code in laser assembly unit? I replace it with used laser assembly so it will have no box or any doc.
    thanks before.
  • charm5496
    • 2387
    Re: IR7200 replace laser assembly
    thanks before.
    I have swapped dozens of these laser units from used machines and have never went through that adjustment procedure before. Are you sure that the laser you are putting was good before installing it?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      If you have replaced the laser unit, enter the value indicated on the
      label attached to the laser unit from 0 to 4807
      Also work without this settings like Charm say.
      • madu132
        • Dec 2008
        • 65
        ok, thanks for clarify Charm, I will try it.
        Zoraldinho, can you make it more clearly which label is it? there are 3 labels on the assembly. 2 of them have more than 4 digit number, there is one have marking *D333*, is this what you mention ?
        thank you
        • teckat
          • 16083
          Go for it/ usually adjusts it self/ as said by others
          COPIER>ADJUST>LASER>LA-DELAY
          0 to 4807
          Use it to adjust the delay line of pixels so that laser A and laser B may be
          coordinated in main scanning direction.
          label attached to the laser unit.
          LA-PWR-A
          Use it to enter the power adjustment value for laser A.
          Range of adjustment 0 to 255
          If you have replaced the laser unit, enter the power adjustment value
          for laser A indicated on the unit.
          LA-PWR-B
          Use it to enter the power adjustment value for laser B.
          for laser B
          DLY-FINEChecking for a Laser Delay
          Use a magnifying glass to make sure that the distance between
          a and b in the figure is a specific distance; otherwise, try changing the setting under COPIER>ADJUST>LASER>DLY-FINE.
          • stosh
            Does anybody have a suggestion on where to buy a refurb' laser unit online? Long story but a 7095 was dropped in my lap but the catch is the laser unit is missing so I'm looking to buy a replacement unit to get the machine up and running.
            • charm5496
              • 2387
              In the US you have NWRS or Hytec to order them from.
              • teckat
                • 16083
                Warning---- do not buy a FM2-5449-000/FM2-5449-010 unless it was repaired for the defective Laser Diodes /E110/Low Density/& Mirror Image==== ask for paper work
                only Nation-Wide Repair Service, Inc. & HYTEC did the repairs for Canon
                Cost is about 800.00/ 1,700.00 US
                imageRUNNER 7105 / 7095 / 7086
                Laser Scanner Assembly is FM2-5449-010
                CAL 866.655.8676---Nation-Wide Repair Service, Inc.
                Circuit Board Repair, Canon, Ricoh, Savin, Lanier Gestetner, Konica, Kyocera Mita - Nation-Wide Repair Service, Inc. (NWRS)
                Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
                800.883.1001 - 407.297.1001
                • stosh
                  Great information thank you! I spoke with NWRS and they have it. Thank you everybody for the help!!!!!
                  • charm5496
                    • 2387
                    Awesome!!!
