CLC 3200 paper size problem
  • goldencup
    • Nov 2008
    • 366
    Hi,
    I have a machine CLC 3200 and here is the scenario:
    my set up is Auto Paper Select
    1st Paper Tray LTR: LTR original on platen glass, i make copy OK!. On ADF OK!
    2nd Paper Tray A4: A4 original on platen glass, i make copy OK!. On ADF OK!
    3rd Paper Tray A3: A3 original on platen glass, i make copy OK!. On ADF OK!
    4th Paper Tray Folio: Folio original on platen glass, A4 is being displayed. On ADF it feeds then stop and the display on screen says:"Load LGL paper size" and the 3rd Paper Tray (which is A3) is blinking
    How can i make Folio auto detect on platen and on ADF?
    my adjustments are:
    COPIER>OPTION>CST
    U1-NAME (1)
    U2-NAME (1)
    CST-U1 (35)
    CST-U2 (35)
    COPY>OPTION>MODEL-SZ (3) AB/INCH
    is there an adjustment for ADF so it can detect Folio?
    I try to use LGL paper size but the paper jams on fusing unit (it is because LGL is 8.5x14 while my paper is just 8.5x13 right? )
    any idea on this matter? Thank you very much.
  • teckat
    • 16083
    Re: CLC 3200 paper size problem
    COPIER>OPTION<BODY>---Level 2
    SCANSLCT (Used to turn ON/OFF function that calculates scan area from selected paper
    size.)
    0: OFF (Scan area is determined by document detection.)
    (Value at time of factory shipment/value after RAM clear)
    1: ON (Scan area is determined by paper size.)
    >ORG-LGL (Used to set special paper size not compatible with DF size recognition.)
    0: LEGAL (value at time of factory shipment/value after RAM clear)
    1: G-LEGAL
    2: FOOLSCAP
    3: A-FOOLSCAP
    4: FOLIO
    5: OFFICIO
    6: E-OFFICIO
    7: A-OFFICIO
    8: M-OFFICIO
    9: B-OFFICIO
    • goldencup
      • Nov 2008
      • 366
      Thank you very much sir! i will do this adjustments on the machine.
      • goldencup
        • Nov 2008
        • 366
        sir i did the adjustments that you gave me. When i try to place a Folio original on the ADF, the paper feeds then stops. The 4th Paper Tray (Folio) is now detected, but the screen still displays "Load LGL paper size". Also I place a Folio original on the platen glass but A4 is till detected. What seems to be the problem?
        • teckat
          • 16083
          If drawer eligibility for APS/ADS is set to off for the paper size you are copying symptoms will occur.
          Check the following for APS/ADS settings:
          * Select Additional Functions/Common Settings/Drawer Eligibility for APS/ADS. Make sure the setting is 'ON' for any mode/paper size required.
          what did u do in this setting below/ ????/
          size.)
          power off/on to take effect
          • goldencup
            • Nov 2008
            • 366
            already checked: all are ON
            COPIER>OPTION<BODY>--SCANSLCT
            my setting is 1. I did turn off/on the machine
            • teckat
              • 16083
              COPIER>OPTION<USER> level 2
              • SIZE-DET (Used to turn document size detection function ON/OFF.)
              0:OFF
              1: ON (value at time of factory shipment/value after RAM clear) (When pressure
              plate opens/closes, optics don’t light, eliminating dazzle.)
