IR 5055N ERR0 E0004-0103
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    This machine having run 50 copies now shows error E0004-0103 remember the wiring had been destroyed by the rats and rewired.Whenever i try to reset in service mode the error re-appears ,checked the fuser element tis ok and the whole fixing unit.even fixing unit switch pcb all components are ok.Any suggestions welcome ,thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IR 5055N ERR0 E0004-0103
    Check Fixing Thermistor
    Due to the breakage of Dumet Wire of the Fixing Thermistor, (abnormal rise in temperature)/ E004 (IH
    Power error/ IH Control Mechanism error) may occur.
    You have all new destroyed cables i believe.
    • Monsoon
      • Nov 2009
      • 16
      I had this issue and had to replace DC.
        • Aug 2011
        • 279
        Heater element does not go on at all ,any problem with the DC pcb?
        • gensys
          • Jan 2011
          • 323
          http://www.copytechnet.com/forums/ca...4-00103-a.html
          The Road will be Mastered by >>> the Going...
            • Aug 2011
            • 279
            Thanks so much Gensys for your referal thread on ir 6570 it really assisted me a lot.Infact there were faulty components caused by the acidic urine of the rats.some diodes were shorting and rusty resistors were replaced and machine running ok. Let me in a special way thank Teckat for the illustrative diagrams posted on that thread thanks so much guys!
              • Aug 2011
              • 279
              sorry for not mentioning the board in question ,it is the Induction heater supply pcb.
              • zoraldinho
                • Mar 2008
                • 5015
                Buy a cat my friend.
                • mramlawi
                  • Jul 2011
                  • 838
                  i have same problem since 2 months and i didnt left anything to change from dc,ih pcb,main board,unit one , duplex,cylinder , drum unit ,ac pcb,upper assembly and the error wont go , till i changed the machine body to another one ,but i didnt stop seeking for the solution but till now i didnt know what is going on in this machine ,as i read the in the previous threads i noticed that this happened with lots of colleagues and i have a question where the IH cable guide unit located ,and i didnt know where actually is it the one that the unit 1 connect it inside the machine !!
                  im totally dizzy with that problem :/
                  Distinguished road makes you jewel in rough
                  • imhotep
                    • Apr 2011
                    • 2
                    basically, e004 related with the fuxing unit. Have u tried to swap a whole fixing unit from other machine? If u've tried to swap with other unit and the result were still the same, then the problem might be at your DC controller or the wiring after fixing unit to DC Controller.
