IR8500 Output smudge/white line
  • mezerwi
    • Aug 2010
    • 58
    [CQ] IR8500 Output smudge/white line
    Hi,
    It happen when the machine being shut down for 2-3 days.
    Image above is generate using PG 1 test print.
    Does it relate with the laser?
    Mezerwi
  • kingpd@businessprints.net
    • 921
    Re: IR8500 Output smudge/white line
    Is it consistent every time at the same spots or random? Does it do it when printing and copying from different sources?
    • mezerwi
      • Aug 2010
      • 58
      Almost consistent
      Yeah
        • 921
        Have seen similar things in that family but not exactly the same as yours.
        Recommended things to check, start with the easiest:
        1. is it on a carpet
        2. is the electrical sufficient and properly grounded
        3. have you cleaned or replaced the coronas
        4. how old is the developing unit/when was it last changed
        5. when was the last time the drum blade was replaced (i think they're good for like half a million then you flip them)
        6. other thoughts, power board bad laser near death
        Seen these issues before in same family but I never got to the bottom of it before replacing since newer machines were cheaper than parts but I'd bet the problem lies in the above.
        It's a lot of potential areas to check and I wouldn't just go buy new parts, you want to try and hone in on the problem, although it can be a b*tch at times.
        teckat, blackcat, or charm do canons more i think so maybe they can offer better advice.
        Good luck and let us know of further developments.
        • vigour
          • Aug 2010
          • 1038
          HOW MANY COPIES ON M/C?
          is it on letter paper too?
          looks like a flat spot on some roller, or a gear issue, some hesitation along the path.
          stop m/c see if it shows up before the fuser
          lower fuser roller, reg roller maybe
          • mramlawi
            • Jul 2011
            • 838
            change the corona's and check the develpoment unit check the bering inside ,check the drum if there's something jamed and u couldnt see it till u disassemble .
            reply to us
            Distinguished road makes you jewel in rough
            • gensys
              • Jan 2011
              • 323
              Originally posted by mezerwi
              Hi,
              [ATTACH=CONFIG]13155[/ATTACH]
              Mezerwi
              Change the corona's & Drum
              The Road will be Mastered by >>> the Going...
