Canon NP 6230/E711
  • cucuklotz
    • Mar 2007
    • 611
    Canon NP 6230/E711
    HI,
    Customer called with E711 service code each time they turn on and off.
    I have very little exp. on this machine.Can I reset and if so how do I enter the service mode to do so?
    ANDY
  • lkrsardis
    • Dec 2007
    • 316
    e711
    Andy e711 means that ic106 on the dc controller has gone out. Replace the DC controller.
    Like the United States Postal Service It's a miracle it works!
    • cucuklotz
      • Mar 2007
      • 611
      Canon Np 6230/e711
      HI
      I,ll order DC controller today.
      THANK YOU
      • cucuklotz
        • Mar 2007
        • 611
        Canon Np6230/e711
        HI<
        Is it possible it could also be the Large Capacity cassette unit(PEDASTAL)
        ANDY
          • 23009
          Are you getting your E711 at power up, maybe with duplex jams? Check sensor PS7 in the reversing guide assembly. It is the #2 leading assembly inlet paper sensor.
          • cucuklotz
            • Mar 2007
            • 611
            Canon 6230/E711
            THe E711 occurs at power up.Ill check out duplex sensor on WED.
            THANKS, ANDy
            • cucuklotz
              • Mar 2007
              • 611
              canon np 6230/E711
              I went to machine today I checked and disconnected the pedastal and 711 code clears up.I checked sensors on pedastel and duplex unit and they are ok.iS IT A GOOD ENOUGH CHANCE THAT THE CONTROLLER BOARD ON PEDASTAL UNIT IS THE PROBLEM,and I would be fairly OK ordering it?
              THANKS,ANDY
              • Canuck
                Tech Specialist
                • 1713
                Re-seat all the connectors on the d-con,etc..before you throw a board at it ..composite power supplies on these machines are notorious for cracked solder joints
                • petrus
                  • 155
                  E711 on np6230
                  yes i am agree that sometime the padastel connector are loose.
                  try disconnect all connector to pcb.
                  its nut man.
                  • cucuklotz
                    • Mar 2007
                    • 611
                    Canon Np 6230/E711
                    HI,
                    Thanks for info,Ill check when I go back to machine,Right now I diconnected unit and customer is using upper trays,and they havnt said a word(There were some other issues with soft,breaking apart trasnport rollers in unit anyway.
                    ANDY
