IR6570 print/copy poor
  • msmy
    • May 2010
    • 123
    Hi guys,
    Currently my IR6570 machine give very poor quality of print/copy as attached.
    Action: Change with new corona wire and clean-up main unit.
    anyone could help me with this problem.
    msmy
  • gensys
    • Jan 2011
    • 323
    Re: IR6570 print/copy poor
    Originally posted by msmy
    Hi guys,
    [ATTACH=CONFIG]13233[/ATTACH]
    msmy
    How many copies the drum printed?
    The Road will be Mastered by >>> the Going...
    • msmy
      • May 2010
      • 123
      near 1.3 Million copy.
      • gensys
        • Jan 2011
        • 323
        Hi guys,
        msmy
        All nodes of a coronary charge have been replaced?
        • msmy
          • May 2010
          • 123
          Yup. All three nods.
          • gensys
            • Jan 2011
            • 323
            Try to polish a drum
            • msmy
              • May 2010
              • 123
              Ok.
              • gensys
                • Jan 2011
                • 323
                See..........Also...............
                Check the surface of the cylinder of the developer unit is not worn, remember that the cylinder of the developer unit of this machine is black.
                check if values โ€‹โ€‹are equal up to the values โ€‹โ€‹of service mode.
                Go to SM and disable the potential control.
                COPIER>OPTION>BODY>PO-CNT (enable/disable potential control)
                0: disable potential control
                1: enable potential control
                If u want it "on" then change C/T corona and clean the PO senzor.
                There is no same problems
                • msmy
                  • May 2010
                  • 123
                  Tq. I'll check it today. cheers..
                  • spectraindo
                    • May 2008
                    • 313
                    What kind of Toner did you use ? Genuine ?
                    • msmy
                      • May 2010
                      • 123
                      Yup. Genuine.
                      • spectraindo
                        • May 2008
                        • 313
                        If that is the situation, I usually polish the drum, change corona wires, clean the dust blocking glass at the laser window and emptying the developing unit and fill it with new toner.
                        Also check the machine's settings is the same as printed on the label on the front door.
                        • PREM AHUJA
                          • 7
                          hello to all respected member,
                          this is my first post to copytechnet.
                          im having similar issue in my ir6570. few days back my main controller failed to work.
                          it takes few 7-8 days to replace the main controller. within this span of week it was heavy rainfall
                          in my area. after turning on the machine i did not get the copy quality as i was getting before.
                          the tech told me it would take a day to recover the machine to its original copy quality.
                          but still after 4 days im not getting the required quality.
                          whether its copy or print its not coming black its in grayscale. i mean to say very light.
                          ANY HELP OR SUGGESTION
                          • spectraindo
                            • May 2008
                            • 313
                            There is a Drum Heater Switch located above the Power cable inlet. The with dot should be pushed to turn on the Heater.
                            Because of the heavy rainfall, the Drum get humid and will not give a good copy quality.
                            Turning On the Drum Heater will get rid of the humidity of the Drum, usually 6 to 12 hours.
