IR c3080I drum
  • vstar
    • Aug 2007
    • 176
    IR c3080I drum
    Customer wants us to replace one of the drums, and I was wondering is there a reset that I need to do and if so could someone please tell me ( IE service mode and sim)
    Cameron
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: IR c3080I drum
    This model have automatic reset counter.
      Re: IR c3080I drum
      Do a full auto-graduation adjustment after replacing the drum.
      The drum count in service mode / display / misc should be zero.
      • vstar
        • Aug 2007
        • 176
        Re: IR c3080I drum
        Thanks everyone.
        Skynet, how do I access servic mode on this model?
        Cameron
        • zoraldinho
          • Mar 2008
          • 5013
          Re: IR c3080I drum
          • vstar
            • Aug 2007
            • 176
            Re: IR c3080I drum
            Thanks zoraldinho,
            I was at that machine and it is totaly different than I am use to. I had the whole assy out that holds the drums, toner hoppers, and transfer belt, but I can not figure out how the drum (black) comes out.
            Could someone please tell me or send me the instructions to do this.
            Thank you to everyone
            Cameron
            • Paul 75
              • 97
              Re: IR c3080I drum
              Once you've got the process assy out , push the button on the top of the ITB assy. This will release and you then lift up the ITB to the left. It will stay upright on its own. Then there is a white slide lock that sits on top of all drum units, slide to the right and then pull out drum towards you.
              Job done..... Full Autograd when machine goes into ready.
              Oh...... I can't copy at the moment then ? !!!!!!
              • vstar
                • Aug 2007
                • 176
                Re: IR c3080I drum
                Thank you Paul 75, I will get back there today.
                Thanks again
                Cameron
