IRAC 2030i error e020-0360
  • HELIO240
    • Jan 2011
    • 137
    [Error Code] IRAC 2030i error e020-0360
    hello people I'm iR2030i displayed intermittently E020-0360, I know it's an error to supply cyan, now what can I do to solve this error once.
    Dc-con in version 40.03
    thanks.
  • charm5496
    • 2387
    Re: IRAC 2030i error e020-0360
    thanks.
    You may want to double check your manual:
    Problem :
    The imageRUNNER ADVANCE displays an E020-0360
    Solution :
    The imageRUNNER ADVANCE will display this error because the contact for the black developer is bent, this causes a poor connection between the black developer and the DC controller. The part number for the contact is FM3-8111-000.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      http://www.copytechnet.com/forums/ca...light=ira+2020
      • danikelado
        • Nov 2011
        • 2
        • teckat
          • 16083
          The imageRUNNER ADVANCE will display this error because the contact for the black developer is bent, this causes a poor connection between the black developer and the DC controller. The part number for the contact is FM3-8111-000. See the following photo of the damaged developer contact.
          • godyng
            • Dec 2008
            • 40
            You must need to chaange the new hopper with new Parts No.
