CANON IR5000 E00061-0001 !
  • sweet.persona
    Engineer
    • Nov 2009
    • 415
    Hello friends
    i have ir5000 copier , Appear an err E000061-0001 , i have reset the machine but the err was still consistent !I have checked The laser shutter / laser unit is not faulty DC controller too is not faulty but In vain ,LCD still displays this damn err ^^.
    can anyone help me . Lot of thankx
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • alaa1005
    • Jul 2011
    • 4
    Re: CANON IR5000 E00061-0001 !
    That is mean the problem in potential control so turn it off from option in service mode and check if the error appear again.
    • gensys
      • Jan 2011
      • 324
      E061-0001 is generated when potential control is being performed
      After the power is turned OFF/ ON, a jam (0A07) is displayed
      In this machine, potential control (default) is performed when the fixing unit temperature is 150 C. or lower when the main power is switched ON.
      Potential control can be toggled ON/ OFF in service mode COPIER> OPTION BODY> PO-CNT.
      E601-0001 detection :
      When the result of potential control is that the white drum surface potential (VL2) is around 200V (the potential for a solid black image).
      To Check
      When E061-0001 is displayed when electropotential control is ON, check the following under service mode COPIER> DISPLAY> DPOT>
      For each item, the normal values and error values are given below.
      'VDT' copy bright area electropotential target value (Normal 390V Error 390V)
      'VDM' copy bright area electropotential measurement value (Normal 390V Error 0V)
      'PLMT' copy primary charging current control (Normal 0 Error 1)
      When there is no primary charging on the drum surface during electropotential control, VDM (copy bright area electropotential measurement value) becomes 0 and PLMT tries to raise the primary output during electropotential, so 1 is displayed.
      Also, as primary charging bracketing, the normal values and primary output error values are given below. When the laser output is normal, LLMT is 0.
      Check the following items under COPIER> DISPLAY> DPOT>.
      'VL1T' copy bright area electropotential target value (Normal 115V Error 115V)
      'VL1M' copy bright area electropotential measurement value (Normal 110V Error 0V)
      'LLMT' copy laser power voltage control (Normal 0 Error 0)
      Check for any broken primary charging wires or leak from the primary charger.
      in iR 5000 series mashins>>> error 061-0001 may be also...................
      When copy power is switched ON, caused by malfunction of the manual-feed door open detection sensor (MSW2).
      Open and closed status of the manual feed tray assembly is detected by the manual feed tray open/ close sensor (PS33) and the manual feed door open/ close detection sensor.
      The manual feed tray open/ close sensor (PS33) detects that the manual feed tray is closed and, due to a malfunction of the manual feed door open/ close detection switch (MSW2), or a broken wire, there is no 24V output from the inrush current protection PCB to the HVT PCB, so there is no primary charging voltage output and if a malfunction occurs in the manual feed door open/ close detection switch (MSW2), error E061-0001 is generated.
      Field Remedy
      Check the manual feed door open/ close detection switch (MSW2) and the mounts and cables around the switch. If the switch is malfunctioning, replace it.
      FG2-6932 High voltage switch unit
      Anyone help You
      Good Luck
      The Road will be Mastered by >>> the Going...
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4999
        E061
        Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
        PCB is faulty. The DC controller PCB is faulty.
        Mode of
        Detection
        0001 As the result of potential control, the drum surface potential (VL2)
        of the white background is about 200 V (generating solid black images).
        0002 The primary charging output used for print output and the drum
        surface potential after laser output has been made are about 200 V
        • ikon01
          • Apr 2011
          • 53
          is the drum turning?there is a gear screwed to the drum drive shaft at rear frame.i've had the screws snap twice causing this error.may be worth checking!
          • agscopycenter
            i have the same problem regarding the error e00061-0001, it can be reset but it took along hours before it will reset, everytime i open the machine the error appear, can any one help me
            • SCREWTAPE
              East Coast Imaging
              • 3396
              What have you done so far???
              • agscopycenter
                I tried to check the primary assembly, i changed it to a new one, then i reset it again, and the error was gone, i think it the problem is the primary assembly as of this time but i wll observe it for the whole day because it is now functioning.for the past 4 years that i am using canon ir5000 it s my first time to met this kind of error.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  I'll give you another tip. When turn on the machine listen for the laser, its the real high pitch noise.
                  How old is the drum & what's the meter on this device.
                    • 16083
                    Check MSW2, the switch could be mis-adjusted or loose.
                    next--------------------
                    Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
                    1) A solid black copy means laser is defective.
                    2) A white copy means you should check the Primary corona and HVT.
                    3) A good copy means you should check the Potential sensor PCB.
                    • Simons
                      • Jun 2008
                      • 490
                      It can happen if the sensor is dirty OR THE DRUM NEEDS POLISHED. That is your easy fix.
                      • ARUN MISHRA
                        • 80
                        THANKES ALL
                        sigpicARUN KUMAR MISHRA
                        • tinnyjay
                          • Oct 2009
                          • 655
                          Originally posted by sweet.persona
                          Hello friends
                          This error is caused also by discharging lamps(led) of drum.
                          Once i opened drum unit and demaged one of wires of led lamps after i turned on the machine it showed me this error code.
                          If leds do not work the cleaning blade could not clean properly the drum.And it looks like is plated with toner and sensor reads out that toner causing the error code.
                          "Who loves the roses,must also bear thumbs"
                          • ivanusicnm@gmail.com
                            • Oct 2012
                            • 22
                            Hello friends
                            REPLACE PRIMARY CORONA
                            • blazersnfkrz
                              • Feb 2018
                              • 5
                              may I know sir what is an HVT?
