canon IR2016 weired problem!!!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    Hi to all tech
    i have canon ir2016 , it was normaly ,one day i trun the copier On and Directly after Period warming up , the copier Begin copying Very quickly Then stoping and showing JAMS.
    what is this type from Faults !
    i replaced DC PCB and cleaned all the sensors but In vain!
    can anyone help me!
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • vigour
    • Aug 2010
    • 1038
    Re: canon IR2016 weired problem!!!!
    maybe your copy button is stuck
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      it is not Bouton issu , Copied at high speed rotation is very unusual!!
      DAMENE ABDEL AZIZ
      DJELFA
        • 23003
        Have you checked jam codes, error codes?
        Is this machine a network printer? Jobs can remain in the queue, waiting for an opportunity to print.
        My suggestion is:
        1) disconnect the network cable, then power On. What happens?
        2) remove all paper, then power On. What happens?
        No. Specifically, What happens?
        And what error or jam codes? =^..^=
        • vigour
          • Aug 2010
          • 1038
          is this your problem?
          you say you turn machine on
          machine warms up
          then machine starts to copy by itself fast.
          is that correct?
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            i do all ur steps friend BLACKAT but nothing !!!! it is the same prblm
            yeah friend vigour when i turned the m ON and after warming up the copier start copying veryyyyyy fast and doing 3 jam
            thankx in advace friends
            DAMENE ABDEL AZIZ
            DJELFA
            • Elizaldo
              Check the M204 and its conector, J208 (the code is FK2-1080)
              If it doesn't work, I recomend you to update the firmware. I think the copier is jamming because of the high speed (why it's fast I don't have any idea), and the sensors are detecting the paper in the wrong time.
