CLC 1140 with jitter banding
  • scottblock57
    • Jul 2025
    [CQ] CLC 1140 with jitter banding
    single color, all colors. jitters are cross feed. stronger in center area of 11x17.
    anybody seen this? and what is the answer?
  • teckat
    • 16083
    Re: CLC 1140 with jitter banding
    make sure the drum gear is clean / also check the transfer drum gear/
    The photo drum gear (300T) could have damaged teeth. When these teeth engaged the transfer drum gear, they will push away from each other.
    inspect the drum weights on the rear of printer
    Check that the Post Cleaning Corona Assembly is not arcing.
    • charm5496
      • 2387
      i also remember the retention assembly causing banding on these units as well.
      • kajsa39
        • May 2008
        • 28
        Retention unit clutches need to be cleaned.
