Canon IRC2620 Connection to Network "cross cable"
  • jcontractor
    • Aug 2010
    • 247
    Hi,
    It is possible to connect a Canon Copier directly to a computer using the RJ45 cable or network connection cable without connecting the machine through a router or switch.
    I want to try this, machine is having a "waiting to print" massage and I want to know how to connect it to my laptop to dismiss any network hardware failure.
    It is a simple office router, the machine have a assigned valid IP address, it have the UFR print driver into a XP-32 bit PC. I want to connect the machine into a 64-bit Win 7 laptop.
    If is possible!!!
    Any help will be really appreciated.
    • 23007
    Re: Canon IRC2620 Connection to Network "cross cable"
    I don't see why not. That's an excellent way to rule out network communication issues.
    Just note the static address of the MFP; i.e. 192.168.1.200
    On your laptop set a static address in the same IP range (change only the last octet); i.e. 192.168.1.210
    Connect your crossover cable.
    Ping the printer's address to confirm connection.
    Load a print driver.
    That's it.
    I can often skip the last step since I have 75 or more print drivers loaded to the laptop. I just select a new port in the print driver.
    • jcontractor
      • Aug 2010
      • 247
      Just note the address static address of the MFP; i.e. 192.168.1.200
      That's it.
      Thanks a lot for your comment.
      I will perform this as soon as I can.
      I notice that the machine gave me this massage "PDL process error", I saw that the PDL information is stored in the HDD of the equipment, if is possible that this data is corrupted or missing?
      Thanks in advance.
        • 23007
        It could be either corrupt print data or a print controller problem. This is the way to sort it out.
        My bet is on corrupt print data. The first step is to re-load the driver. =^..^=
        • jcontractor
          • Aug 2010
          • 247
          Well I notice that I perform a HDD format where the PDL data was stored in the HDD, the procedure indicate a re-load.
          One big problem: I don't know how to re-install the PDL data. I don't know if I need the service program for this machine.
          As a recommendation from a post I perform the step # 3 without reading carefully about the procedure.
          This information below comes from a IRC 3200 service manual machine.
          I do the procedure due a "waiting to print massage", I realize that the error massage "PLD error" comes after HDD formarting. What a mess!!!!
          Caution The following must be kept in mind and the user must be properly informeded
          of the fact when using CHECK-TYPE:
          0: entire HDD → no operation occurs (to initialize, use the SST)
          1: image storage area → removes image data
          2: general-purpose file area (user settings data, various log data, PDL spool
          data, image data control information) → initializes files
          3: PDL-related file storage area → removes font data, requiring re-installation.
          What I can do?
            • 23007
            This is the point where I must defer to someone with more recent Canon printing experience. I've taken you as far as I can. =^..^=
            • jcontractor
              • Aug 2010
              • 247
              Thanks.
              • vigour
                • Aug 2010
                • 1038
                you need to reload system software with service support tool
                • jcontractor
                  • Aug 2010
                  • 247
                  Thanks, unfortunetly I don't have it.
                  How I can get this tool?
                  Or is only for Canon dealers?
                  • charm5496
                    • 2387
                    are you sure that your machine even has print capability installed into it?
                    You need to get into service mode and check your boot rom version. It it is a 'C' then you are just wasting your time trying to connect it to print and firmware will not help you.
