Canon NP 6020 Jams at output
  • silverfox
    • Jun 2025
    Unit meter reads 143,367. Drum replaced around 139,000.Canon dealer no longer supports due to age. Looking for someone in Cleveland, Oh area to service. Looks like a piece of cloth at the final rollers. Correction model is NP 6030.
    • 22999
    Re: Canon NP 6020 Jams at output
    Could it be an NP-6025 or an NP-6030 maybe?
    If yes, it's probably the web you're looking at. =^..^=
    • silverfox
      Missed my coffee. It is an NP 6030
        • 22999
        If your hear any loud snapping or popping sounds, it my brain straining back 10 years ...
        I found this record. Maybe it will help:
        Web feeds out of the copier. The fixing fan seizes causing heat fatigue in the web advance gear 37T. Gear 37T breaks where it links to the web core. With no web drive, the web can unwind freely. Replace the fixing fan assembly new style (FG5-3318-020), which incorporates the duct into the fan housing. Replace web advance gear 37T new style (FF5-5707-000), Also check top and left side covers for heat damage.
        Good luck finding any of these parts nowadays. This machine has been unsupported for a long time. If the web has been in the machine over a year, the heat will evaporate off a lot of the fuser oil, causing it to resist unrolling. It can sound like its ripping, it's glued on so tightly. If the web has been there for over a year replace it (if it's available). =^..^=
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Should be easy to find someone in Cleveland that can remove the fuser. The cleaning web has wrapped around the rollers and needs to be removed. Then the old web just needs to be reinstalled or if it is too damaged....a new web installed. It's a very simple repair on that model. After installing the web your tech can actuate the web drive by hand to see if the gears are feeding the web properly. Good luck ......
