Canon ImagePRESS Server Q1
  • alexctx
    • Dec 2010
    • 157
      • 16083
      Re: Canon ImagePRESS Server Q1
      Originally posted by manuelubau
      When i connect the box to a monitor, windows starts loading and then this image appears
      [ATTACH=CONFIG]14218[/ATTACH]
      I did check if the Hard drive was correctly connected and it was.
      You can not connect >
      the Fiery box directly to a PC to check the Fiery HDD
      • manuelubau
        • Aug 2011
        • 62
        Do you have a parts catalog for the server? I have a tough time knowing the name of each part or which connector is which. thanks. It is an used server. When we got it, it was fine, but an employee connected an additional LAN cable to the ImagePress C1 and the server's screen went blank.
        Edit: also I have no support from canon here. since advanced systems like these are not available in this country. if you could give detailed instruction how to test things I would appreciate it.
        Thanks a lot for your help!
          • 16083
          #19
          What are u talking about ?? additional LAN cable to where on C1 ??
          I posted the Q1 Manual already--here it is again-
          click on link>>>>>imagePress Q1_I&SGl.pdf
          parts sheet>>>Q1_Parts.pdf
          • KL568
            _
            • Feb 2011
            • 324
            #20
            Correct me if I am wrong, what you have done is:
            Connect a monitor to the VGA port of Fiery
            Bootup process on the monitor can see Windows logo, then that blue screen above?
            Not for the faint-hearted [jokingly], connect a keyboard and mouse to Fiery, press F8 key BEFORE the Windows logo showup. Should be presented with a few option on black background, select the option "Last known configuration..." If this cant solve your issue, best you get hold of the setup CDs to re-install the system.
            • manuelubau
              • Aug 2011
              • 62
              #21
              Originally posted by KL568
              I did that and still got the same result. and yes you are correct.. I connected a monitor to the VGA port of the Fiery.
              • KL568
                _
                • Feb 2011
                • 324
                #22
                Think you ran out of any options to recover this Q1. Only a fresh installation of the system from CD will clear this infamous BSOD.
                • zukol21
                  • Feb 2012
                  • 14
                  #23
                  Hi im having the problem with my Q1 too. Where can i get the firmware and system update files?
                  Thanks in advance!
