Roller Mark - Fuser?
  • rjk-consultants
    • Aug 2025
    [Misc] Roller Mark - Fuser?
    Hi Guys,
    I am having a problem with a canon ir2270, I have attached a copy of the problem - Black roller mark equal spaced out on the paper.
    It only appears after the fuser unit - however none of the rollers are that size near the fuser unit.. so I am thinking its a mark on one of the rollers/films in the fuser unit.
    I am still a BIG newbie when it comes to copiers.. infact its the only one I am supporting, normally I just look after printers.
    can anyone throw me some ideas.. and if its the fuser unit that needs replacing then where I can get one from - google is normally my friend but not today :-(
    hoping some one out there can help...
    Ry
    Untitled.pdf
  • Tec1
    • Dec 2011
    • 48
    Re: Roller Mark - Fuser?
    if you run 5 copies, do marks move around or stay in same area?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Replace the drum.
      • rjk-consultants
        Sorry for the delays guys.
        They slowly move by about 1inch per sheet
        The drum looks clean no marks what so ever - ( I would have thought to have seen some marks like I do on replacing hp laserjet fusers)
        The only part of the fixing unit that has any marks on is the silver roller and thats caked in black specs.
        sorry if I am coming over dim - I know i should treat it like a large hp laserjet.
        I thought about replacing the drum but dont want to look like a muppet infront of the customer if it didnt fix it.
        Ry
        • kuby
          • Oct 2007
          • 1409
          Looks like the drum to me.....
            • 23009
            If the interval is 95.5mm it's the drum. It's probably not cleaning an area of the drum due to wear on the surface. =^..^=
            • Victor285
              • Jul 2010
              • 61
              Originally posted by rjk-consultants
              Hi Guys,
              Ry
              [ATTACH]14163[/ATTACH]
              Its the Drum, Replace the Drum!
