Canon IR5000 E0014
  • hamdyyassin
    • 84
    Canon IR5000 E0014
    I have an error e0014 in my copier ir5000, I changed the dc controller an the feeding unit.
    I check the connnectors but the error is still occur.
    thanks for help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5001
    Re: Canon IR5000 E0014
    You have the same issue with IR5570
    • gensys
      • Jan 2011
      • 324
      If the fixing motor (M19) is normally rotated by rotating the fixing knob lightly during warm-up rotation, it is possible that torque of the motor (FH6-1996) became insufficient. So, replace it with a new one
      Turn the fixing knob.
      If the fixing knob does not rotate smoothly, check to see if the fixing or pressure roller rotates.
      If the ball bearing does not rotate smoothly, replace it with a new one.
      The Road will be Mastered by >>> the Going...
      • bukhari
        • Feb 2013
        • 4
        ever there was someone who disassemble the motor fixing ir5000 ? how ?
        • pinkia
          • May 2009
          • 19
          This error concern with fixing drive before going to cross check fixing motor plz check pressure roller bearing might be they cut the pressure roller rode.
          • northernlife
            • Sep 2011
            • 847
            Two screws on the front fixing cover (need to open front door it's the top tray that slides out). Take off the cover and the motor will be right in front of your face. Don't take it apart replace it, you'll be there again the next morning with a rather irrate customer.
            If you have sales people give them the lead, despite the fact 5000's are rock solid machines it should have been replaced by now.
            • dan7777
              • Dec 2012
              • 680
              http://www.copytechnet.com/forums/ca...570-e0014.html
              Check the pressure roller bearings. Check the web for build up.
              • Canuck
                Tech Specialist
                • 1713
                You said you replaced the feeding unit....does that mean the whole transport drawer with fuser included. If you did and still have error, check the connector inside the machine at rear(from the front) that the fixing drawer connector plugs into for a piece of paper or pieces inside connector. Clean inside connector with sandpaper and alcohol. If you cheat front cover, does fixing motor turn? As mentioned make sure rolls,bushings and bearings are good before digging in
