problem in ir 1600 copy quality
  • eng_migo
    • Jun 2008
    • 16
    [CQ] problem in ir 1600 copy quality
    i have a machine canon ir 1600 when it print the quality is perfect but when it copy the copy was very light from the top
    plzzzzz help
  • ernesto
    • Oct 2011
    • 430
    Re: problem in ir 1600 copy quality
    plzzzzz help
    Hi may be, the cs unit doesn t work right FG6-8359-000 1 CS UNIT
    good luck
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      1.Copyboard Glass, Reading Glass, and Back of the Copyboard Cover (retainer)
      Open the copyboard cover, and wipe the parts with a cloth moistened with water (well
      wrung); then, wipe them with a soft, dry cloth.
      2.Contact Sensor
      Remove the 2 screws, and detach the copyboard glass; then, remove any dirt from the lens
      array of the contact sensor with a soft, dry cloth.
      • teckat
        • 16083
        plzzzzz help
        TOP ??? which direction
        have u checked the optics ? are u a tech ?
        • eng_migo
          • Jun 2008
          • 16
          is there anyway to increase quality by software (service mode)
          i c many parameters in the service mode but don't know the use of it
          • teckat
            • 16083
            why don't u buy a Manual ?
            • Simons
              • Jun 2008
              • 490
              I cant remember which But I think the reader board was replaced in some for poor copies. if you had light prints I would blame dev unit or drum but since your prints are good you should also check copy off the glass and check doc feed adjumnet.
              • COPIERTEC ASSOCIATES
                • Aug 2011
                • 279
                I had almost a similar scenario that on prints from via the pc the prints were fine but on copying the copies were generally light.I opened the laser unit cleaned its optics and the copies were so fine.You could give it a try,good luck!
