Canon iR2880i E748-4311
  • Jamesu
    • Mar 2012
    • 101
    Re: Canon iR2880i E748-4311
    Sorry, scratch the whole laser change.
    I did that on a machine the customer had previously in. I haven't changed the laser at all on this 2880i !!
    My mistake! Sorry!
    Have you tried turning it off and on? No...Oh, it works now!
    • Jamesu
      • Mar 2012
      • 101
      Yep! I'll have a go with it when I'm in the office later!
      Thanks for the help!
      • Jamesu
        • Mar 2012
        • 101
        I have tried removing and re-seating the board that goes to the left of the HDD (Vertically - RB-A2 PCB ASSEMBLY)
        Still have the same error code.
          • 16083
          #19
          RB-A PCB=PCL Printer Kit-Q1
          PS Printer Kit-Q1 requires that PCL Printer Kit-Q1 and iR 512MB Expansion RAM-C1 be previously installed.
          Color PS Printer Kit, it must be activated by registering a
          license key,
          after the memory of the machine has been expanded to 1,536 MB
          this is for the 3380/2880 series and not the i series
          did u check the memory set up/
          In order for the PS Kit Q1 to work correctly the PCL Printer Kit Q1 is required
          • Jamesu
            • Mar 2012
            • 101
            #20
            Photocopier has been fixed!!
            Thank you all for the help!
            It was a dodgey connection on the DC-Controller!
              • 16083
              #21
              what is a dodgey connection ???
              to me it seems that u created more of an issue then u originally had-
              When a working printer is shipped from one location to another/ before my techs power it up>
              they check all those inserted PCB's on Main C- to make sure nothing popped lose>
              • Jamesu
                • Mar 2012
                • 101
                #22
                One of the connections that was in the DC-Controller wasnt slotting into its slot correctly.
                It wasn't a board, it was a connection onto a board.
                • Jamesu
                  • Mar 2012
                  • 101
                  #23
                  That's usually the way with me, a problem that would take someone a week to figure out I do in 2 mins. Yet a simple problem takes me forever
                  • donald-tillman@att.net
                    #24
                    Could someone post a photo/diagram of the cage with the copier in view? I need to talk someone through this and a photo would help big-time.
                      • 16083
                      #25
                      READ THIS PDF--
