cleaning transfer belt
  • worm
    • Nov 2011
    • 36
    [Misc] cleaning transfer belt
    what can i clean the transfer belt with on a c3220
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: cleaning transfer belt
    If the blade is not cleaning the ITB, it has to replaced.
    Here is the part number: FG6-8989-030000
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • charm5496
      • 2387
      if you have glue or some other foreign body on the ITB causing image quality issue I always use a clean cotton pad with rubbing alcohol
        • 23009
        Better than alcohol, use paraffin lamp oil and a webril pad. It removes adhesive quickly with little scrubbing, and does not damage transfer belts, organic drum coatings, ASi drums (as if anything could damage those). Of course, you do have to make sure it's completely evaporated before putting the unit back into service. =^..^=
        • Rachid.Akli
          • Oct 2011
          • 595
          Rachid.
          Sorry, i was thinking about the cleaning blade.
          For the ITB, i used to clean it with alcohol.
          Rachid.
          • pontiac
            • 420
            We have been using 99% alcohol and cotton pads for years.
            • teckat
              • 16083
              Harmful if inhaled or swallowed. Highly flammable. Keep away from sources of ignition: No smoking.
              Eyes: May cause irritation.
              Skin: May cause irritation to skin.
              Ingestion: May cause gastrointestinal discomfort.
              Inhalation: May cause irritation to respiratory tract.
