Canon iR Advance c5045 error code E000602-1113
  • apollo
    • Mar 2008
    • 191
    [Misc] Canon iR Advance c5045 error code E000602-1113
    Hi
    I had error code E000602-1113.
    I done HD Check in service mode and updated to the latest Firmware few times from USB Mem stick
    and also the updater.
    but now i do not get full menu screen.
    Can i enable it service mode?
    U can print to the copier but cannot copy as the menu does not appear.
    see attached only 3 items appear on the menu screen on the left pic and also attached pic from similar machine
    what the menu should appear like.
    thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon iR Advance c5045 error code E000602-1113
    Use the button in upper right corner on the display and click show all.If you don't see more options you have missing files in firmware.
    • KL568
      _
      • Feb 2011
      • 324
      Hi,
      The other thing beside corrupted firmware installed, you might want to check under Service Mode setting with "UI-COPY" set it to 1. Think it under Level 2 of Func-SW?
      • apollo
        • Mar 2008
        • 191
        Hi
        Pressed button show all and checked service level 2 and setting is on 1.
        Still no joy screen as per pic.
        Any further input please.
        • KL568
          _
          • Feb 2011
          • 324
          Originally posted by apollo
          Hi
          That's hard nut to crack! Can think of couple options
          1 Do a P-print of a good copier & compare it with the problem one, line by line way
          2 OR Do a backup of every single thing that you can think of, DC-cont / R-cont. Nuke it with MN-cont CLEAR and cross your finger after the multiple reboots will it the true life.
          3 OR grab another HDD replacement for the problem machine. After that, find another working machine to test the HDD that you swap out.
          Good Luck
          • KL568
            _
            • Feb 2011
            • 324
            Good Luck
            Just thought of another thing, before this error code to replace HDD does the machine has a licsence know as Access Management Kit?
            • apollo
              • Mar 2008
              • 191
              Hi,
              i wil find out regarding access management kit and
              give you feed back.
              • teckat
                • 16083
                Hi,
                give you feed back.
                Main Controller 1,
                Main Controller 2,
                Ram Memory and Flash Rom contacts clean and re-seat
                • KL568
                  _
                  • Feb 2011
                  • 324
                  Originally posted by teckat
                  Main Controller 1,
                  Main Controller 2,
                  Yes, Teckat's much simpler than mine. High chance poor contact of these items, especially between MN-Cont 1 and 2 is Connector PCB. During first few batch, it was giving weird problem
                  • apollo
                    • Mar 2008
                    • 191
                    Thanks for the reply.
                    Will try resetting all memory and controller boards.
                    • apollo
                      • Mar 2008
                      • 191
                      hi
                      have clean contacts and reseated cont1 and cont2 and all memory modules.
                      still the same symptoms.
                      installed new controller-1 and memory modules and prior to changing the contoller done back up
                      and restore on new controller-1 and updated firmware with the latest and the fault still there
                      with missing icons.
                      when you press all only the option for 3 icons appear and in service level 2 iu copy and other setting is set to 1.
                      any other suggestions please.
                      • KL568
                        _
                        • Feb 2011
                        • 324
                        Firmware updated as in override on previous version?
                        Try format HDD
