ir8070 SST download nightmare
  • ymmtech
    • Jun 2009
    • 190
    #16
    Re: ir8070 SST download nightmare
    Ever consider non standard way as second chance?
    • jiongpao
      • May 2009
      • 414
      #17
      I dont get what you mean?
      • ymmtech
        • Jun 2009
        • 190
        #18
        Playing with disk cloning tools..,,,, so long if you have another working one.
        • jiongpao
          • May 2009
          • 414
          #19
          Ohh ya im downloading HDClone Professional, Acronis and Norton Ghost. Gonna try it soon. Hopefully it may work
          What do you recommend for cloning tools ymmtech?
          • ymmtech
            • Jun 2009
            • 190
            #20
            I use WinHex for disk image backup/restore, MHDD to fix disk error and HPA the disk.
            • spectraindo
              • May 2008
              • 313
              #21
              I have sent you the ift files, if the error still persist ,disable firewalls and internet security programs that may block the IP address.
              • DAG COPIERS & COMPUTERS
                • Oct 2010
                • 860
                #22
                And if all else fails, do not overlook or ignore the data transfer cable (bus) which interfaces between the main controller PCB and the hard drive. Too often we assume that this cable never "go wrong".
                • jiongpao
                  • May 2009
                  • 414
                  #23
                  yes im using same ip range for laptop
                  I will try again and see what will happen. If the problem still the same i might use cloning system.
                  • bad78
                    #24
                    i use HDclone profosional and it work for me
                    • jiongpao
                      • May 2009
                      • 414
                      #25
                      Well, downloading the software using SST to ir8070 doesnt work for me even i changed the cross over cable, changed network card for ir8070. I used HDClone software to clone the hardisk from other ir8070 machine and it work perfectly. Thanks everyone here for trying hard to guide me
