Repetitive marks on copies (black) IRADVC5051
  • rayjeek
    • Jun 2010
    • 239
    [CQ] Repetitive marks on copies (black) IRADVC5051
    I have IRADVC5051 with a repetitive black marks on outboard part of prints. This happened after changing CYM drums and running Autograd. Changed black drum afterwards but still not resolved. Next area to look at will be dev/film/ITB. When printed A4R no marks seen. Any help to pinpoint the fault most welcome. Sample attached for your analysis. Thanks.
    • 23009
    Re: Repetitive marks on copies (black) IRADVC5051
    IMHO the interval is too close for developing. Probably probably primary charge (roller?).
    • seniortech
      • Dec 2007
      • 180
      Check for a torn fixing film and/or worn fixing pressure roller.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Can be a fixing issue but, to be shore,make a force stop before fuser and check.Also check charge roller like Cat say.
        • rayjeek
          • Jun 2010
          • 239
          Thanks to all who contributed and those yet to. Will get back to customer tomorrow with parts mentioned and give you feedback.
          • arielcanon
            • Mar 2012
            • 106
            if the problem comes from primary roll the pitch will be approx 4.5cm, but you have replaced with new drum and the problem still appear. I aggre with zoraldinho to check the print output before fixing...
            Learning never ends..
            Never give up, where there is a wheel there is a way..
            • eric
              • Oct 2010
              • 25
              l had this problem 2days ago ,it's was the bloc dev BK (a problem with the manetic roller,at the front edge)
              • rayjeek
                • Jun 2010
                • 239
                Just an update: it turns out to be a damage to the Bk mag roll hence replacement of dev unit resolved the issue as Eric mentioned. Thanks to all.
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Hi
                  If it's a fixing issue, there would be other color marks (not only black). It seems to a black dev issue. Verify the dev cylinder and the dev assembly life in service mode>counter. Remember that the developper is in the dev assembly which is given for 500k prints.
                  Rachid.
                  "Find a job you love and you’ll never have to work a day in your life." Nagy's father
