ir600 0110 code
  • copicatt
    • Nov 2008
    • 366
    ir600 0110 code
    Hey guys, have an account that is some distance away. They are getting jams when doing 2 sided only. had her look at the jam code and it is 0110 the last several times (delay at u turn sensor). I know on the 5000, there is a little white arm that cracks, does the 600 have this.....runs single sided fine........just getting tips before I head that way in the morning....I recently rebuilt the fuser, but this is a totally different jam than I was getting then. Did notice the Big black "hook arm" on the back of the claw assembly was worn down but that wouldnt affect this, you just have to shut the claw unit slowly or it wont pivot down right....been that way a while... thanks!
  • teckat
    • 16083
    Re: ir600 0110 code
    0110 Jam Code, stationary jam at PS14
    check or replace PS14, Pre-Confluence sensor located in the Duplex Feeder -
    Pull out the duplex tray and open the upper inlet guide, gray smoked plastic, and check the lead edge for burrs or ridges due to paper cuts. This is especially problematic if heavy paper stocks are used. The paper cuts will catch the paper and cause either jamming or damaged edges to the paper.
    • copicatt
      • Nov 2008
      • 366
      Re: ir600 0110 code
      Hey teckat, thanks for the reply, but my manual shows a delay jam at the u turn sensor (ps13). Is that correct for the iR600?
      • teckat
        • 16083
        Re: ir600 0110 code
        u have the correct info from the book/
        but also check PS14 in I/O address for change of state
        • Chameleon
          • Nov 2011
          • 200
          Re: ir600 0110 code
          I would also get a set of duplex rollers, FB4-2142, FF5-7736, FF5-7738. After a few million and since they must be 10+ years old they get flat spots, glazed over and the diameter decreases. The duplex is different form the 5000, it is more like a 7200 or 105.
          The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
          • copicatt
            • Nov 2008
            • 366
            Re: ir600 0110 code
            Update: pulled unit 1 and duplex unit from working machine. Installed them, ran 40-2 sided.......then same exact jam, 0110 jam code........ok, strange....
            • Chameleon
              • Nov 2011
              • 200
              Re: ir600 0110 code
              At least you eliminated the duplex assy. You can eliminate the delivery assy by running face down output. I would assume that will jam 1 in 40 as well.
              Some things I've seen cause duplex jams are the small auxiliary rollers (FB4-2315) in the fuser delivery assy that drive the paper to the duplex assy get glazed over. In that same area are some spring loaded white (or black) guides, after a few million they wear down and get indents that catch the lead edge and I've seen a few where the springs on them are missing. GL
              • copicatt
                • Nov 2008
                • 366
                Re: ir600 0110 code
                swapped entire unit 1 (fuser and all), no change
                • teckat
                  • 16083
                  Re: ir600 0110 code
                  Time for signal checks !!
                  • Desert Rat
                    • May 2008
                    • 1089
                    Re: ir600 0110 code
                    DCON clear. I know it's kind of a pain but I have seen it clear up odd problems.
                    Just a thought.
                    DR
                    • copicatt
                      • Nov 2008
                      • 366
                      Re: ir600 0110 code
                      Yeah, that would be next, but I think they are gonna upgrade now
                      fine by me!
