i back with pucture to my problem ir 6570
  • bluesky2000
    • 95
    hi all
    i came back ...
    this is my problem
    1- i put the paper in feeder A4R
    2- and i hit the green key for copy then look it's A3 ... why ?
    i want to be A4R and print it from cassette #3 ...
  • vigour
    • Aug 2010
    • 1038
    Re: i back with pucture to my problem ir 6570
    you have to do feeder width sensor adjustments.
    • teckat
      • 16083
      Poster has been given adjustment procedure before--
      COPIER > FEEDER > FUNCTION
      TRY-A4 Use it to execute automatic adjustment of paper width detection
      reference point 1 of the ADF original pickup tray. (A4)
      TRY-A5R Use it to execute automatic adjustment of paper width detection
      reference print 2 of the ADF original pickup tray. (A5R)
      TRY-LTR Use it to execute automatic adjustment of paper width detection
      reference point 1 of the ADF original pickup tray. (LTR)
      TRY-LTRR Use it to execute automatic adjustment of paper width detection
      reference point 2 of the ADF original pickup tray. (LTRR)
      COPIER > OPTION > BODY
      MODEL-SZ ---Use it to switchover the default magnification ratios and ADF original size detection.
      0: AB (6R5E)
      1: inch (5R4E)
      2: A (3R3E)
      3: AB/inch (6R5E)
      select 3 > if u use both AB and Inch Paper / or 0 if u use only AB Paper
      if the DF has no issues with other size paper recognition /
      replace sensor in tray
      or ADF driver PCB
      AB/INCH identification sensor
      PI3
      The machine possesses the following 2 modes of operation to suit different printing modes:
      a. normal mode (other than mix of different configurations or extra-length)
      Original size identification
      Feed direction== monitors the state of the post-separation sensor (on/off) after the read sensor goes on to identify the original as being small or large.
      Sensor used==post-separation sensor, read sensor
      checks the length of the original placed in the original pickup tray;identification of LTR and LGL.
      Sensor used==LGL sensor
      Cross-feed direction==checks the width of the original placed in the original pickup tray.
      Sensor used==original width volume (VR1)
      identification between A4R/A5R and LTRR/ STMTR
      Sensor used==AB/inch sensor
      A. Normal Printing
      The machine identifies the size of an original with reference to combinations of the size (width, length) detected on the original tray and the size (length) detected while the original is being moved.
      a. Detecting the Size of the Original in Feed Direction
      The machine detects the size of an original in feed direction with reference to the state of the post-separation sensor (PI7) after the read sensor (PI8) has gone off and the state of the LGL sensor (PI4)on the tray (LGL/STMT).
      The machine measures the length of the time from when the read sensor goes on to when it goes off to find out the length of the original; it then uses the result of the measurement and the result of detection made on the original tray to identify the size of the original.
      When an original is placed on the original tray, the light-blocking plate operates in keeping with the detecting lever of the LGL sensor to block the light of the photo interrupter. The machine identifies whether or not the original is LGL with reference to the LGL sensor signal (LG_S) and the width of the original. The machine communicates the original size information to the host machine as soon as the Start key is pressed.
      b. Detecting the Size of the Original in Width Direction.
      The width of an original is detected using the original width detecting volume (VR1) found inside the original tray.
      The volume operates in conjunction with the slide guide, its resistance changing (analog) as the slide is moved. The ADF driver PCB reads these changes in resistance as the original size signal (WIDTH), and recognizes them as specific widths.
      To make sure that the original width volume (VR1) correctly detects A4R/LTRR and A5R/STMT widths, a special AB/inch sensor (PI3) is used inside the original tray; the sensor goes '1' (AB/inch identification signal) when the width of the original is 197 mm or more and less than 214 mm.
      The track of the slide guide is given a groove so that the slide may stop at specific default sizes. Some sizes, however, are extremely close to each other, possibly causing the slide to stop at the wrong point. To make sure that the slide stops at the correct stops, the slide is provided with a positioning roll
      • bluesky2000
        • 95
        i have three machine
        i change the feeder with another one
        and still the same problem
        can u show me anything by image
        • arielcanon
          • Mar 2012
          • 106
          does the feeder work correctly on the other machine?
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • kingpd@businessprints.net
            • 921
            Did you try any of teckat's recommendations? Switching the feeders isn't going to do anything.
            • teckat
              • 16083
              RCON values are stored in printer ---
              RCON (reader controller)The reader controller is also used to control the ADF.
              what happens when u place A4R paper direction on the glass > close cover > and hit print key ?
              does it pick-up from A4R paper in tray ? or ask u to load that size ?
              ADF
              • bluesky2000
                • 95
                i am sorry for late my friend
                @ teckat @
                i do it today i will put a paper on glass A4R and i hit the green key
                and i told you what happen?
                look this problem happened when i rest the machine for service mode i rest it from copier>function > clear :
                and i rest Everything that exists in ( clear )
                • teckat
                  • 16083
                  @ teckat @
                  like I said it's the communication between the DF and the Reader-------------
                  did u check the RCON settings
                  Original size detection=
                  ADF mode
                  main scanning direction: by slide guide in ADF
                  sub scanning direction: by photo-sensor in ADF
                  Reader Controller PCB--
                  J201 = used for input of power from the machine (printer unit) correct DC 24/13/5/3.3voltages
                  J202 = used for communication with the ADF (sensor signal input, fan control, scanner motor control, controller)
                  J203 = used for communication with the printer unit; connects to the scanner motor; used for communication with the ADF; used for input of image signals
                  J207 = used for connection with the original size sensor (AB).
                  WHEN U CLEAR RCON
                  3) Enter the appropriate settings for the following
                  items in service mode:
                  a. settings indicated on the service label (found behind the reader unit front cover)
                  a-1 image read start position adjustment (X direction;
                  in fixed reading mode) COPIER>ADJUST>ADJXY>
                  ADJ-X
                  a-2 image read start position adjustment (Y direction;
                  ADJ-Y
                  a-3 shading position adjustment (in fixed reading
                  mode)
                  COPIER>ADJUST>ADJ-XY>ADJ-S
                  a-4 feeder mode main scanning position adjustment
                  COPIER>ADJUST>ADJ-XY>ADJ-Y-DF
                  a-5 ADF stream reading CCD reading position
                  COPIER>ADJUST>ADJ-XY>STRD-POS
                  *The machine retains ADF-related service data in the
                  RAM of its reader controller,
                  thus necessitating ADF adjustment whenever you
                  have replaced the reader controller or initialized the
                  RAM.
                  b. original stop position adjustment
                  FEEDER>ADJSUT>DOCST
                  c. original feed speed (magnification) adjustment
                  FEEDER>ADUST>LA-SPEED
                  4) Make adjustments using the following service
                  mode items:
                  a. ADF sensor sensitivity adjustment
                  FEEDER>FUNCTION>SENS-INT
                  b. tray width adjustment
                  FEEDER>FUNCTION>TRY-A4
                  FEEDER>FUNCTION>TRY-A5R
                  FEEDER>FUNCTION>TRY-LTR
                  FEEDER>FUNCTION>TRY-LTRR
                  c. white plate data adjustment
                  COPIER>FUNCTION>CCD>CCD-ADJ
                  d. ADF white level adjustment
                  COPIER>FUNCTION>CCD>DF-WLVL1
                  COPIER>FUNCTION>CCD>DF-WLVL2
                  --Be sure to perform white plate data adjustment before performing ADF white level adjustment.
                  After having made the foregoing adjustments, put the
                  P-PRINT printout in the service book case, replacing
                  the previous P-PRINT printout.
                  • bluesky2000
                    • 95
                    ok first when i put paper on glass in A4R and close the cover hit green key it's work print from third cassette but when put the paper in feeder A4R and hit green key it's not work before 2 month the machine work fine and the feeder work very good and print form any cassette
                    • mramlawi
                      • Jul 2011
                      • 838
                      LIKE
                      ADF mode
                      WHEN U CLEAR RCON
                      ADJ-X
                      ADJ-Y
                      mode)
                      RAM.
                      FEEDER>ADJSUT>DOCST
                      mode items:
                      Distinguished road makes you jewel in rough
                      • teckat
                        • 16083
                        that's because u cleared the settings
                        >>> your DF feed settings need to work in conjunction with the Reader settings-
                        • bluesky2000
                          • 95
                          ok what are the value for DF when i choose it . i need the setting and the number
                          thanks so so so much for your help my best friend
                          i do that :
                          and when i hit green key for all command write to me " OK "
                          ONLY THIS
                          COPIER>FUNCTION>CCD>DF-WLVL2 ---- write NG not ok !!
                          • bluesky2000
                            • 95
                            a. settings indicated on the service label (found behind the reader unit front cover) where is that !
                            • teckat
                              • 16083
                              Removing the Reader Front Cover
                              1) Remove the screw [2] (1 pc. each) from the left and right of the reader front cover [1].
                              Detach the reader front cover [1] in upward direction [1].
