and i don't have the original P PRINT SETTINGS FOR THIS PRINTER
my friend do not be angry
i'm not angry label missing in action
get a P print from another 6570 > u need to get those RCON default settings back to something other then default #'s
ok what are the value for DF when i choose it . i need the setting and the number
ONLY THIS
COPIER>FUNCTION>CCD>DF-WLVL2 ---- write NG not ok !!
For WLVL2 adjustment you need to put 2 sheets of paper in the document tray.
For WLVL1 you should place paper on the glass especially if your white copyboard is not clean.
my friend i search in right and left and front reader cover i don't find any things about service label
i have some question :
1- all device 6570 have the same label
2- can try another solution
3- did you have a real image fro this service label
i hate the company .................................
sorry I posted on that left cover --that was for 4570/---
this is the 6570 parts pic--label /FC5-2940-000/location/ inside front cover--I can't explain why it is missing--
did u check this sensor below ADF open/closed sensor 2 identifies the state as being "closed," and the machine starts original size detection. Here, B5, B4, A4, and A3 are eliminated from the list of possible sizes.
check these settings in service mode/ should not be set to default settings
a-1 image read start position adjustment (X direction; in fixed reading mode) COPIER>ADJUST>ADJXY> ADJ-X
Use it to adjust the image read start position (X direction). adjustment range: 1 to 100 (default: 20)
a-2 image read start position adjustment (Y direction; in fixed reading mode) COPIER>ADJUST>ADJXY> ADJ-Y
Use it to adjust the image read start position (Y direction). adjustment range: 47 to 131 (default: 90)
a-3 shading position adjustment (in fixed reading mode)
COPIER>ADJUST>ADJ-XY>ADJ-S
Use it to adjust the point at which data is collected for shading using the standard white plate. adjustment range: 20 to 200 (default: 50)
a-4 feeder mode main scanning position adjustment
COPIER>ADJUST>ADJ-XY>ADJ-Y-DF
Use it to adjust the main scanning position for feeder mode. adjustment range: 21 to 106 (default: 53)
a-5 ADF stream reading CCD reading position
COPIER>ADJUST>ADJ-XY>STRD-POS
Use it to adjust the CCD read position forDF stream reading mode. adjustment range: 1 to 200 (default: 100)
