i back with pucture to my problem ir 6570
  • bluesky2000
    • 95
    #31
    Re: i back with pucture to my problem ir 6570
    this is a pacture for the setting
    but still when i put a paper A4R in feeder the machine read it is A3 whyyyyyyyyyyyyyyyy ??????????
    • teckat
      • 16083
      #32
      don't know-
      when u place the paper A4R on the glass in it's direction--
      then close cover and hit print key what exactly happens > does it default to the A4R Paper tray and print-
      if so ----and the issue is only when u use the DF>>>
      the only things connected for communication between DF>READER>& PRINTER are Interface PCB>DF Cable > READER pcb > DF open/close sensors 1 & 2 >slide guide in ADF for main scan>photosensor in ADF for sub-scan
      have u checked the Interface Pcb ??? it serves as the interface with the printer and ADF
      look at this in service mode---
      COPIER > FEEDER > DISPLAY
      >FEEDSIZE
      indicates the size of the original identified by the feeder.
      COPIER > FEEDER > DISPLAY>FEEDSIZE>TRYWIDE
      indicates the distance between original width detecting slides (detecting the width of paper; 0.1 mm).
      indicates the distance between the slides used to detect the width of originals in the ADF original tray (between 2 points).
      place A4R paper in DF > close down> check reading above
      Did u perform all the checks under COPIER > FEEDER > FUNCTION
      do u have a 6570 MANUAL
      • bluesky2000
        • 95
        #33
        yes when i put the paper A4R on the glass it's read it A4R and print with any problem
        but when i put A4R on the feeder read it A3
        >FEEDSIZE
        COPIER > FEEDER > DISPLAY>FEEDSIZE i check it the feedsize is --------- it's empty
        and i have the service manual
        • teckat
          • 16083
          #34
          Did u do the A4R paper check in ADF Tray for below ?????????????? to see if size is shown-
          • bluesky2000
            • 95
            #35
            YES i check it is a number not A4R or A4 or any thing else just a number
            COPIER > FEEDER > DISPLAY>FEEDSIZE>TRYWIDE --- it's 2370
            i am sure the problem on the feeder and need to Programming again >>
            • teckat
              • 16083
              #36
              place paper in A4 direction to see if # changes ~
              TRYWIDE=
              2,370 millimeters is equivalent to 93.3 inches something is wrong
              237 millimeters is equivalent to 9.33 inches
              A4= 210mm x 297mm
              8.27inch x 11.69inch
              • bluesky2000
                • 95
                #37
                is there any solution to fix it
                look
                sometime i see in COPIER > FEEDER > DISPLAY>FEEDSIZE>A4
                and another time i see COPIER > FEEDER > DISPLAY>FEEDSIZE>A3
                and when i turn off and then turn on the machine i see
                COPIER > FEEDER > DISPLAY>FEEDSIZE> --------
                is there any problem !!!!!!!!!!!
                In all cases when i put a paper in feeder A4R and hit hit green key read it A3
                this problem with three machine
                Observation :
                when i put paper A4 in feeder and hit green key it's work and read it A4 and print from cassette 1
                when i put paper A3 in feeder and hit green key it's work and read it A3and print from cassette 4
                the problem only with A4R in feeder ??????????
                • teckat
                  • 16083
                  #38
                  simple_____________
                  so A4R is in cassette 3 ???/ have u tried cassette 4 for A4R ?
                  will other paper sizes be recognized in the A4R cassette when using DF
                  what happens when u put A4 paper in cassette 3 or 4 and try to use the DF
                  Type=plain paper (64 to 90 g/m2),recycled paper,colored paper,heavy paper (91 to 200 g/ m2),bond paper
                  Cassettes=
                  Size--A3, B4, A4R, A5R, B5R, LDR, LGL, LTRR, STMTR,A4, B5, LTR
                  Deck (left/right)=Size--A4, B5, LTR--Only
                  Manual Feed=A3, B4, A4R, A5R, B5R, LDR, LGL, LTRR, STMTR,A4, B5, LTR, EXE (bond paper only)
                  Transparency--Manual Feed Only--A4, A4R, LTR, LTRR
                  Postcard--Manual Feed Only--A4R irregular, 2-pane postcard, 4-pane postcard
                  Label Sheet--Manual Feed Only--A4, A4R, B4, LTR, LTRR
                  Index Sheet--Cassettes Only--A4, LTR
                  Tracing Paper--Manual Feed Only--A3, B4, A4R, A4, B5R, B5
                  **Had nothing else better to do~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  • bluesky2000
                    • 95
                    #39
                    what the DF ?
                    did you mean the feeder ?
                    you wont to put A4R in feeder and change the cassette 3 to cassette 4
                    • teckat
                      • 16083
                      #40
                      what the DF ? did you mean the feeder ? you wont to put A4R in feeder and change the cassette 3 to cassette 4
                      the DF = DOCUMENT FEEDER/ U need to check both cassettes for all paper sizes to check operations from DF
                      • bluesky2000
                        • 95
                        #41
                        hi my friend
                        i try it
                        with A4 and A3 it's work and all other size using DF
                        but with A4R use DF read it A3 ?
