Canon iR2020 Blank event self print test
  • nochick
    • Jan 2012
    • 80
    [Dead] Canon iR2020 Blank event self print test
    Hello...
    I just found new one of my iR2020
    it's a Blank page event self print test!!
    So what i'm done.|
    - Replug Boot Rom / PCB / HV / Power Supply / Laser Unit and stay the same
    - new HV-Board /// stay the same
    what I should do next?
    Thank you for help.
    • 16083
    Re: Canon iR2020 Blank event self print test
    Originally posted by nochick
    Hello...
    So what i'm done.|
    Thank you for help.
    Bias-
    ASIC on the DC controller PCB outputs the developing AC bias drive signal (/DVACFOT), developing AC bias ON/OFF signal (/DVACON), developing DC bias drive signal (/DVDCFOT), and developing DC bias output level signal (/DVDCPWM) to apply the voltage generated by superimposing the developing AC bias over the developing DC bias to the developing cylinder.
    Drum Unit ? rotation ?
    Developing
    Assembly
    Transfer charging roller
    Image Processor
    PCB
    • nochick
      • Jan 2012
      • 80
      [QUOTE=teckat;304427]Bias-
      Drum Unit New one and rotation is looking good clutch and motor seem normal
      Developing is good condition
      Assembly
      Transfer charging roller new one
      Image Processor
      PCB
      this is what I suspect too there's no other part ..
      my supplier told me he always solve this out with changing
      1st HV-board most of blank page fix with this
      2nd DC-control
      3rd PCB
      4th Laser unit
      but I try 3 HV-boards but it's not solve
      The machine run smooth no paper jam or else except blank page
      meter about 400,xxx
      oh and I just found This machine is iR2020J not iR2020
      Thank you so much teckat but It's seem no hope for me.
        • 16083
        u said Dev unit is in good condition
        did u stop copy process( sky shot )half way (create a jam) to see if an image is on DRUM ?
        did u check the output voltages from Power Supply ??
        to Image Processor= +5v/+3.3v
        to DC PCB= +24VR/+24V/+5VR/+3.3VR
        to HVT= +24VR/+5VR/+3.3VR
        OUTLET=source of AC voltage power is as specified (+/-10%). The power plug must never be disconnected day and night.
        • nochick
          • Jan 2012
          • 80
          Thank you teckat
          I create a jam and no image on drum
          but I didn't check output voltages from Power Supply I will try
            • 16083
            When the drum unit is drawn out, the interlocked laser shutter moves down, shutting off the laser beam path. When opening of the front cover or left door is detected, the laser scanner motor and laser outputs turn off.
            Laser beam reflected by the hexahedral mirror focus on the photoconductor drum via the imaging lens and loop-back mirrors installed before the hexahedral mirror.
            When the hexahedral mirror rotates at a constant speed, the photoconductor drum is scanned with laser beams at a constant speed.
            When the photoconductor drum rotates at a constant speed and the photoconductor is scanned with laser beams at a constant speed, a latent image is formed on the photoconductor drum.
            The laser exposure system is controlled mainly by the IC5 on the DC controller PCB.
            The DC controller PCB sends laser control signals (CNTRL0, CNTRL1, and CNTRL2), which are used to switch between laser driver operation modes, to the laser driver IC along with video signals (VDO1, /VDO1, VDO2, and /VDO2). The laser driver IC controls laser emission (ON/OFF) according to the combination of CNTRL0, CNTRL1, and CNTRL2 signals
            • COPIERTEC ASSOCIATES
              • Aug 2011
              • 279
              I had a similar fault at one time , changed the laser unit and machine worked.Try it out as Teckat has explained above.Good luck.
              • nochick
                • Jan 2012
                • 80
                thank you COPIERTEC ASSOCIATES and teckat I just changed the laser unit and machine worked It's take a long time to find a good laser unit in my country. The new one is very expensive...
                  • 16083
                  thanks--------------------good luck
                  • valeter1961
                    • Sep 2011
                    • 11
                    Re:bizhub c450
                    Hi again do you know error codes for bizhub c450? as im getting error code c-d307 any ideas please
                      • 16083
                      Re: bizhub c450
                      U sure if that is exact error code ?
                        • Aug 2011
                        • 279
                        Cheers and thanks for your effort too..............!!
                        • valeter1961
                          • Sep 2011
                          • 11
                          Re: bizhub c450
                          im pritty sure but i will check it again later or maybe just D307 as c- maybe not part of it ?
                          Regards
                          Keith
