IR2200 2nd side cross feed reg problem
  • Brian8506
    • 1616
    Single sided is fine. When doing 2 sided from glass, thru adf or mailbox 2nd side off about 1/4 inch in the cross feed direction. Thats after adjusting adj-refe to -50, the highest setting. I'm suspecting horizontal reg motor m3 but havent gotten e051 codes. Wondering if any of you have had this. TIA
    • 22599
    Re: IR2200 2nd side cross feed reg problem
    I can't remember if the iR3300 has a horizontal registration sensor. It was really common on NP-3030, NP-3050, and NP-4050 to have toner dump into that optical sensor. As a consequence the horizontal registration motor always ran all the way to the end. Now it surprises me that you don't see the effect on the first side, but I suppose it's possible.
    The only thing that pops up in the database is a separate adjustment for DADF main scan registration, second side. =^..^=
    • Brian8506
      • 1616
      I believe there is a sensor but it doesnt usually get dirty. If I'm right its on one end of the pfu by the motor. I played with that df adjustment. It helped copy thru df but off glass and print doesnt change. I'm gonna go back with a motor and try my luck.
      • Brian8506
        • 1616
        Replaced horizontal reg motor and that fixed it.
          • 22599
          Thanks for following up. Congratulations. =^..^=
