ir4570 some kind of smudge on lines
+ More Options
Posts
  • goldencup
    • Nov 2008
    • 366
    [CQ] ir4570 some kind of smudge on lines
    Hi, any idea where this problem is coming? (see attached image) I have replaced, developing unit, drum unit and transfer roller. This is just an enlarge scan of test pattern 9 so that you can visibly see the problem.
  • kuby
    • Oct 2007
    • 1389
    Re: ir4570 some kind of smudge on lines
    Have you changed the fuser unit or inspected it?
    • Luther
      • May 2006
      • 682
      I agree Kuby, looks like the fixing film, ive been running into a lot of this
      • arielcanon
        • Mar 2012
        • 106
        common problem with this model.
        ensure that u use OEM toner, check fixing film rotation, check pressure, check bearing.
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          The other responses are spot on... it's a fuser issue. And--- as arielcanon said----never never use generic toner in this model.
            • 22989
            Wow! am I late to the party. Oh, what the hell ... Fuser!
            Does the finished image smudge easily when rubbed? =^..^=
            • goldencup
              • Nov 2008
              • 366
              Thanks for all reply, I'll check the fusing unit. By the way, image are not erased and all toners are original
              • goldencup
                • Nov 2008
                • 366
                may i know the grease that is used in the film of the fusing unit? The film seems to be okay and in good condition. By the way what do you use to clean the film.
                • Canon.Tech
                  • Mar 2009
                  • 335
                  If you fit a genuine Canon fixing film unit you don't need to worry about greese, jamming, smudging, they are much better than the crappy non OEM film, nothing but trouble.
                  Also remember to replace the heat sink roller, this can cause smudging/jamming etc when it is soiled.
                    • 22989
                    Use Uniflor: *Tech Aids* UNIFLOR 8172
                    ... and you won't have much luck with cleaning the fixing film. Once it starts collecting toner, it will continue to collect in the same areas again.
                    • Mina Banoub
                      • May 2011
                      • 50
                      <Cause>
                      The moisture held in paper evaporates in response to the heat from the fixing assembly, thus causing toner to fly
                      astray. This problem tends to occur when paper has low resistance and in a high temperature/high humidity
                      environment.
                      <Field Remedy>
                      Use the following service mode item to decrease the developing bias, thus suppressing the symptom:
                      COPIER>OPTION>BODY>FIX-SMR
                      0: default
                      1: decrease the developing bias by a single step (-20 V)
                      2: decrease the developing bias by 2 steps (-40 V)
                      If '2' is selected, the lines can become thinner.
                      <Image
                      • mramlawi
                        • Jul 2011
                        • 838
                        if still faceing the problem as my friends said cahnge the fuser film and check the heat stink as Marc Said
                        Distinguished road makes you jewel in rough
                        • Canon.Tech
                          • Mar 2009
                          • 335
                          Did he just replace the fixing film not the genuine Canon film unit?
