Internal Finisher-S1 on iR-3570
    • 23007
    I'm looking for part numbers for the gripper assembly, the base that the gripper travels over, and the two large eject rollers.
    Or use of a parts manual would due just fine. Our local manuals guy was unable to find that particular one.
    Can anybody help?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: Internal Finisher-S1 on iR-3570
    Binder1.pdf
      • 23007
      Thanks zoraldinho. The rollers are (2) 4A3-1121-000
      ... and the grippers, and base plate? =^..^=
      • Brian8506
        • 1664
        If you're looking for the base that the upper assembly sits on it's 4A3-1047-000 called lower guide
          • 23007
          Just to confirm, Brian, it's the same slotted guide that the grippers ride on? It's gouged up pretty badly by the action of the grippers.
          ... and the grippers?
          • zoraldinho
            • Mar 2008
            • 5009
            Check this
            Binder1.pdf
              • 23007
              Not quite, but thanks anyhow. I found a manual. =^..^=
              • Canon.Tech
                • Mar 2009
                • 335
                Also to add after replacing items 14 remove the small pads item 33 they get sticky & cause all kinds of problems.
                  • 23007
                  I'll watch for it, thanks.
                  The problem I'm having is very intermittent, as in approximately once a year. When the finisher jams are removed a certain way the front gripper hooks onto a feature on the base plate, and cannot return to home position. It gives a E000575-8001 error. It's a 5 minute recovery: pick up on the gripper so it releases, reset Limited Function mode, flip power Off/On. But the enduser is getting agitated. Each of these parts is showing significant wear from the constant back/forth scraping. I've been in there once before so I know what it looks like: lots of mechanical gears and cams. Fun like the iR330 paper feed units ***sarcasm***.
