canon clc 1180 - 1012 ( clc 1100 ) error code: E072002 help please
  • roadster
    • Aug 2012
    • 33
    Hi, New to forum - found you guy's with a google search and looking for help please...
    I have a canon ( model number on side ) clc 1180 - 1012 which has error code: e072002
    I would like to know if this is a easy fix or not.....
    Thanks in advance for any advise....
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: canon clc 1180 - 1012 ( clc 1100 ) error code: E072002 help please
    E0720002
    The motor lock signal
    (TRCMLK) is '0' for 1 sec or
    more while the transfer drum
    cleaner brush motor is
    rotating.
    Reason : To communicate a procedure to take in dealing with the transfer cleaner motor lock error (E072 -0002)
    which can possibly occur as the result of the transfer cleaner relay cable connector pressure terminal
    coming into contact with the separation claw drive plate
    Details : < Procedure >
    When making visits for servicing, attach the edge protection tape to the edge of the separation claw
    drive assembly.
    <Factory measure>
    Edge protection tape has been added to the edge of the separation claw drive assembly.
    • mramlawi
      • Jul 2011
      • 838
      As my college said try to check the Brush some time paper jams and u cant find it till you left the Transfer cylinder ,i occurs again change the brush it will work
      Distinguished road makes you jewel in rough
      • roadster
        • Aug 2012
        • 33
        Thanks for prompt replies - i do not know a thing about this clc1180 - all looks very complicated inside - do you think it would be an expensive fix if i called a repairman out..
        • roadster
          • Aug 2012
          • 33
          when it is starting up panel reads: cleaning wires........
          • zoraldinho
            • Mar 2008
            • 5016
            This is standard procedure.Don't worry.
            • teckat
              • 16076
              call a trained service tech on model----there are many things that can cause the TRANSFER DRUM to freeze up/
              i know a way to bypass the motor lock signal/ little hard to explain here--
              basically u create a short bypass(with a formed U shape paper clip between Transfer drum cleaner
              locking motor-pin 3/orange signal wire
              and Transfer drum cleaner brush motor M8-pin 2/red 24v wire
              one good point just posted about paper stuck in between TD cleaning brushes / if u never seen or worked on this model>>>call for HELP
              another overlooked issue>>>>>for E072
              >>Check both sides of all the door switches for voltage. A switch that is failing will drop the supplied voltage 3 to 5 vdc. Replace the switch. Check both SW4 (Left front cover switch) and SW5 (Delivery Cover switch).
              this E072-002 issue is a pain in the butt/ u have a printer that is over 10yrs old/
              • roadster
                • Aug 2012
                • 33
                • roadster
                  • Aug 2012
                  • 33
                  Hi, I am back again with my E072002 problem - i now have a guy who will fit me a: transfer belt cleaning motor - the problem is finding one - does any one know of any suppliers of either new or used parts in the UK for Canon 1180 - thanks in advance...
                  • roadster
                    • Aug 2012
                    • 33
                    Sorry to be a pain - but does anyone know part number of the canon clc 1180 transfer brush cleaning motor - i have tried a google search with no luck..
                    • teckat
                      • 16076
                      Motor M8=
                      FH6-1569-000
                      click on link # below==
                      Canon FH6-1569-000
                      • roadster
                        • Aug 2012
                        • 33
                        Thank you so much - you are a star - will let you know how i go on....
                        • roadster
                          • Aug 2012
                          • 33
                          still looking for a uk source of: fh6-1569-000 for my canon clc 1180
                          Would this work the same: canon fh6-1567 CLC1150 24V STEPPER MOTOR
                          • teckat
                            • 16076
                            [ATTACH=CONFIG]17259[/ATTACH]
                            it's all about the connector !!!!!!!!!!!!!!
                            / never seen that part # in a 1150 parts book
                            just remembered something important to check--to add on below/ that transfer frame connector can have a crack/
                            There is a possibility that the E072-0002 error code can be caused by an accumulation of toner / starter or most likely torn pieces of paper inside the Transfer Frame Connector.
                            This is a known issue to prevent supply voltages to components --see picture-
                            u need to remove the transfer frame to fully inspect > Frame side Male connector >& look inside interior to check the interior
                            Female connector--
                            pic of frame connectors----
                            • roadster
                              • Aug 2012
                              • 33
                              thanks - will keep looking - just saw it for sale local to me...
