canon clc 1180 - 1012 ( clc 1100 ) error code: E072002 help please
  • teckat
    • 16083
    #16
    Re: canon clc 1180 - 1012 ( clc 1100 ) error code: E072002 help please
    Originally posted by roadster
    thanks - will keep looking - just saw it for sale local to me...
    don't forget to check those connectors ---
    who told u motor was bad ????
    • roadster
      • Aug 2012
      • 33
      #17
      Thanks for tip about connectors.....
      Local copier repair/ service guy says it is motor - stated this over the phone when i told him error code - i am really at his mercy as need to get it up and running
      • teckat
        • 16083
        #18
        NO Color trained CLC1100 Series Tech can diagnose this E 072 error on the phone/
        Canon does not even support this series anymore--
        if I told u home many tech pubs concern this error over the past 10 years--u would faint
        some things that can contribute to E072
        1-Transfer Drawer connector/WIRE HARNESS
        2-A bent separation claw drive plate( that brass leaf plate that rides along transfer drum metal teeth )
        3-Transfer driver PCB
        4-Cracked Frame connector
        5-Cleaner Brushes locked up(paper jammed inside behind rollers)
        6-Door switches (supplied voltage)
        7-DC FUSE PCB
        8-Transfer Cleaning Assembly(housing could be warped or the bearings could be seizing)
        I could go on & on
        • roadster
          • Aug 2012
          • 33
          #19
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5013
            #20
            I had only 2 motor errors in 15 years.
            • roadster
              • Aug 2012
              • 33
              #21
              Thanks for reply, it is just so flustrating trying to get someone local and knows as much as you guy to take a look.. would really like to stick with my 1180...
              • teckat
                • 16083
                #22
                if a tech is not trained on this model or has heavy experience from shop repair/ field repair -
                they are just looking at a manual to see what likely points to error/
                it took Canon field supervisors over two years (1999 > 2002 to try and pinpoint these E072 ERRORS
                • roadster
                  • Aug 2012
                  • 33
                  #23
                  Thanks again - think i am going to go for: Ricoh SPC 430DN
                  • teckat
                    • 16083
                    #24
                    • mbgemini
                      • Nov 2011
                      • 18
                      #25
                      Thanks for prompt replies - i do not know a thing about this clc1180 - all looks very complicated inside - do you think it would be an expensive fix if i called a repairman out..
                      I've got two copiers with ceramic toners too (clc1100 and clc700); I spent 4-5 years in studying guides and manuals. Lots of my problems were so simple, I would have spent too much money calling techs. If you've never seen and used a copier you should spend time in studying (operator's manual first - colorPass user Guides - Service Manual), you could not solve problems with changing it. Ceramic toners cost TOO much to waste them away. I had a service manual from technicians of my copiers, but I've also found it on Internet. If you need something let me know. Good luck!
                      Best regards, Barbara
                      • teckat
                        • 16083
                        #26
                        Over the years there have been over 35 tech pubs just on E072/ those pubs are long gone and not available anymore> unless u saved them-
                        a user or novice on those models is usually lost when it comes to that error/ service manuals will not help on that error> it points to a source direction > that's useless unless u have worked in the field to experience that error-
                        we don't even give contracts on those models anymore & charge 275.00 hr. to service w/ no guarantee on solutions
                        glad to hear about your determination on studying up on this old product/ but somewhat useful printer--
                        • roadster
                          • Aug 2012
                          • 33
                          #27
                          Hi Barbara, Thanks for reply, have downloaded service manual from the internet - but error code: e072002 could be many things.... i would love to get my clc 1180 up and running the ceramic print quality is the best - but i am now looking to go down the ricoh route... you are the first person i have found who uses clc for ceramic printing - thanks for taking the time to reply...
                          • charm5496
                            • 2387
                            #28
                            I still have all my techs pubs on this beast. We still support 3 of them that use the device for promotional type products. No contracts - $125 for every 30 minutes we are there and they eat up the fuser rollers, t-sheets and drums in all of them. Great revenue for us though!
                            • mbgemini
                              • Nov 2011
                              • 18
                              #29
                              No, I havent that pubs, only SM, and I've seen E072 is a difficult error. I haven't found it in my copiers for now, I hope to never found it in the future .
                              In effect I'm not a tech, only a very trained operator - I suppose I could easily become a tech with a teacher - In the last few years I learned to solve lots of my copier errors thanks to my SM, my passion in these machines, and this site too, but I don't pretend to feel like a tech.
                              ...glad to hear about your determination on studying up on this old product/ but somewhat useful printer--
                              we came across these clc machines cause someone - years ago - proposed them for the specifical job we wanted to do: printings with ceramic toners to apply on tiles. If you take a look to the site of the only italian producer of ceramic toners, they still propose CLC 11xx series systems among with other Ricoh models. http://www.balteadc.it/sistemi_en.html
                              Problems are still frequents, but for now I have to make the best of a bad situation !
                              • mbgemini
                                • Nov 2011
                                • 18
                                #30
                                Originally posted by charm5496
                                I still have all my techs pubs on this beast. ...
                                You could even share them !! ... so you could become one of my teachers!!
