If 2nd delivery full sensor flag is mistakely removed during buffer pass unit instalation, sensor keeps reporting tray "C" full state. Reports and P prints etc are printed to "C" output tray by default. If this is the problem in your case then you probably can't execute auto gradation adjustment...
[ATTACH=CONFIG]17067[/ATTACH]
Thanks - auto grad is fine and feeds to the c TRAY - but it is worth a look.
personally I would reset my main controller and RAM first.
If that did not work I would do a full overwrite of the firmware.
If problems still persisted I would do a DCON and then an MN-CON clear
I do agree with Charm.I had a similar fault on an IR6000 and the fault was cleared after re-installing the system firmware.
