Canon ira c5051i
  • dickiebob
    • Sep 2011
    • 66
    Re: Canon ira c5051i
    Originally posted by roller
    If 2nd delivery full sensor flag is mistakely removed during buffer pass unit instalation, sensor keeps reporting tray "C" full state. Reports and P prints etc are printed to "C" output tray by default. If this is the problem in your case then you probably can't execute auto gradation adjustment...
    [ATTACH=CONFIG]17067[/ATTACH]
    Thanks - auto grad is fine and feeds to the c TRAY - but it is worth a look.
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 279
      Originally posted by charm5496
      personally I would reset my main controller and RAM first.
      If that did not work I would do a full overwrite of the firmware.
      If problems still persisted I would do a DCON and then an MN-CON clear
      I do agree with Charm.I had a similar fault on an IR6000 and the fault was cleared after re-installing the system firmware.
      • godyng
        • Dec 2008
        • 40
        HTML Code:
        Must be the HDD problem !
