IRC 2880i Color Displacement
  • boyjorge
    • Mar 2011
    • 37
    [CQ] IRC 2880i Color Displacement
    Good Day to all,
    I have this problem with IRC 2880i with color displacement. I read some post here regarding with this problem and do all they did but the problem still same.
    I do the REG/Clear in service 2 and do quick gradation and full gradation with no effect.
    I do P/Print and DC con clear and put all the value of laser but still problem.
    I replaced the ITB assy with no avail.
    I notice one thing that the pattern of displacement is not changing if i do DC con clear and not putting back the value of laser. Same thing when i replaced with new ITB assy the pattern is not changing or all the things that i have done is not changing.
    Please see attached PG6 and PG10 for reference.
    Any will appreciate all the help.
    Thanks in advance.pg6.jpgpg10.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: IRC 2880i Color Displacement
    Did you clean two itb patch sensors and perform gradation again?
    Error code history?
    Observe ITB patch pattern.Need to figure it out what is the reason for issue.
    • teckat
      • 16083
      Originally posted by boyjorge
      Good Day to all,
      Thanks in advance.[ATTACH=CONFIG]17155[/ATTACH][ATTACH]17156[/ATTACH]
      perform an auto color correction mismatch, Enter Additional Functions Adjustments and Cleaning. On page three select auto color mismatch correction.
      If Auto color correction mismatch is not an option, be sure to update the firmware to the latest version. To clean the patch sensors manually actuate the solenoid to open the shutters and wipe the sensors with a dry lint free cloth.Below is a photo of the solenoid and shutters that cover the sensors.
      Remove the noise dampening pad for the Registration sensor flag
      and then performing Reg-Clear, Quick Adjust and then adjusting the IMG-REG should resolved the issue.
      The ITB Drive Unit needs checking, by turning the ITB Drive Gear manually.
      If the ITB Drive Gear spins free. It is suspected that the ITB Belt was turning; because of the pressure of the turning Drums and not the drive gear.
      Replacing the ITB / Drum Drive Assembly (FM2-5520-000) resolves that gear issue.
      • boyjorge
        • Mar 2011
        • 37
        I will clean that patch sensors and perform auto color correction mismatch tomorrow.
        i will keep you updated.
        Thanks.
        • mjarbar
          As you may have already guessed from your PG10 page, your cyan drum is also on the way out!!! I dont have the service manual with me but if all else fails you can try to input your own values to bring the lasers back into alignment but it is fiddley and a bit time consuming.
          • boyjorge
            • Mar 2011
            • 37
            The culprit is the patch sensor.
            Thanks everyone.
            God Bless
            • mjarbar
              No worries and thanks for coming back and letting us know.
              • zoraldinho
                • Mar 2008
                • 5018
                Thanks everyone.
                God Bless
                No problem
