Getting Blank Screen
  • d-raj
    [Dead] Getting Blank Screen
    Hello,
    I have a Canon ImageRunner C2620. Until a few days ago it was running just fine. A couple of days ago I found that whenever I would turn it on, it would go straight to a white screen on the LCD display and not do anything else. Yesterday, I found that it is not even a white screen but just a blank screen whenever I turn on the machine. The green light for Power Remains on and nothing else happens. When I lift up the cover for the copier, the light turns on for that. We use it as a printer. Any help in how to resolve this would be appreciated.
    Thanks.
  • doktor
    • 214
    Re: Getting Blank Screen
    I would start by reseating the DIMM's and Boot ROM on your main controller. Maybe doing a main controller clear and re-entering your door specs. If you still have the same issue after that I would move to replacement of the main controller and/or DC controller.
    You could also have a pinched wire in a harness, bad fuse PCB, door switches shorting out above the fuser assembly.
    • Rachid.Akli
      • Oct 2011
      • 595
      Originally posted by d-raj
      Hello,
      Thanks.
      Do you mean that the machine is printing?
      If it's the case, i would suggest to change the display.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • shadetree canon
        Be sure to check your plugs on the back of the control panel & lcd display. There is a ribbon cable that connects the lcd to control panel that i have replugged & solved that problem.
        • d-raj
          Thanks. that worked for me. I reseated both the DIMM and Boot Rom and it started working again.
