Canon NP6216
  • Janez
    • Mar 2008
    • 5
    Canon NP6216
    I have a few of these machines that make dirty copies with foggy background. This problems occurs when I add a new toner. I have a few solutions, but none appear to be permanent. I can solve this by making 100s of copies and the copy image gets much clearer. Another solution would be if I suck clean a developing assembly and install a new toner. If you add a new toner before the old one gets empty solves this ploblem, but it's still not a permanent solution for a customer. A already replaced a developing assembly, HVT assembly, drum unit.
  • lkrsardis
    • Dec 2007
    • 316
    np 6216
    Are you using OEM toner with the hologram on the box, or aftermarket toner?
    Like the United States Postal Service It's a miracle it works!
    • matjaz
      • 17
      • Janez
        • Mar 2008
        • 5
        • songela
          • Mar 2008
          • 216
          The cause is toner for sure.
          Just obtain it from a reliable source always, agood packing material or a hologram is not a proof of genuine toner. Otherwise advise the customer to do away with old models which are most characterized with adulterated toners.
          • matjaz
            • 17
              • 23009
              Re: Canon NP6216
              Way back when I was working on Mitas I would see this. The machine would have to undertone before it asked for toner. When toner was installed, the machine dumps in so much toner at once that it overtones. Gradually over 50 to 100 pages, the toner density stabilizes at a normal level. If service was called, the issue usually was gone by the time I arrived. Or if it still was giving a little background, I would run a few 30% fill originals to detone the developer a little. Then I would give a little shrug and move on. The key was knowing that toner was just installed.
              I'm thinking that a Canon NP model must be monocomponent though. After 26 years you might consider selling them something new. =^..^=
              • copier tech
                • 8169
                Re: Canon NP6216
                Bit of a random reply to his Slovenian spam post!?
                  • 23009
                  Re: Canon NP6216
                  LOL! I missed that entirely. =^..^=
                  • copier tech
                    • 8169
                    Re: Canon NP6216
                    Thats not like you!
