imageRUNNER C5030 / C5035 / C5045 / C5051--Transfer Cleaner Assembly Leakage
  • teckat
    • 16083
    [CQ] imageRUNNER C5030 / C5035 / C5045 / C5051--Transfer Cleaner Assembly Leakage
    Publication details how to prevent waste toner from leaking out of the Transfer Cleaner
    Assembly, FM4-7244-010, onto the Yellow Developer Housing. As a result, the Waste Toner will migrate
    in the laser cavity causing copy quality issues.
    ----Transfer Cleaner Assembly Leakage.pdf
  • DMP
    • Aug 2017
    • 26
    Re: imageRUNNER C5030 / C5035 / C5045 / C5051--Transfer Cleaner Assembly Leakage
    Thank You for your 5 years old post. It turned out to be the problem in my case for IR 5235. The rear side of the plastic film was wrinkled causing the yellow to leak on the transfer belt and making yellow stain on one side of the print. No idea how that happened. Transfer cleaning unit has never been out of the machine..
    Thanks again!
    • teckat
      • 16083
      Thanks again!
      Thanks, keep up the great work.
      • tech28
        • Jun 2013
        • 434
        As always teckat, very informative,
        • copier tech
          • 8145
          Latest part number for this cleaning unit is FM4-7244-020
