Configure Counter on Canon
  • sysmonteiro
    • Aug 2011
    • 2
    [CQ] Configure Counter on Canon
    Hi Guys!
    How can I configure the counters in Canon IR 2270 as an example in the sequel 101/401/402/403/404.
    Very grateful for the attention.
    Danilo
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Configure Counter on Canon
    service mode:COPIER>OPTION>USER>COUNTER
    Counter 1 can not be changed
    • teckat
      • 16083
      Originally posted by sysmonteiro
      Hi Guys!
      Danilo
      u need to look in manual for those counter descriptions that u bill customer under>
      other then 101 which can't be changed/
      in service mode>>locate-
      COPIER > OPTION >USER
      COUNTER1
      Setting Software counter 1 on the User mode screen 1
      <Setting value>
      101: Total 1
      [Value at shipping / Value after RAM clearance = 101 -> Cannot be changed]
      COUNTER 2to 6
      Setting Software counters 2 to 6 on the User mode screen
      <Setting range> 1
      0 to 999
      SEE PDF----COUNTERS.pdf
      • sysmonteiro
        • Aug 2011
        • 2
        Perfect!
        Thanks advanced!!!
        Danilo
        • Canon.Tech
          • Mar 2009
          • 335
          What's the best counter number to use for scanning, e.g I want to charge my customers for scanning, sending & faxing but don't want to include copying in this counter?
          I was using 501 but this includes ALL scanning.
          Many thanks.
          • teckat
            • 16083
            Many thanks.
            depends if your printer model (b & W /color) supports these counters---check your manual or read posted pdf above-
            942 = Send scan / FAX (Black-and-white)-depends on fax type(G3)
            944 =Send scan / IFAX (Black-and-white)
            946 =Send scan / E-mail (Black-and-white)
