Iradvc2025 error code e020-1360 after replacing bk drum
Re: Iradvc2025 error code e020-1360 after replacing bk drum
If you are in a pinch, I have swapped the drum chip with the old one and gotten away from this error.
I have a few of these units that will throw a E020-1x60 code on new drum installs and I have tried pretty well everything.
What works 100% for me is to use the old drum chip...pretty quick to swap.
Not the right way to do it, but hell these printers seem to find themselves in the worst places.
CheersComment
Yes swapping the drum chips works, but apparentley shortens the drum lifeLet us eat, drink, and be merry, because tomorrow we may die!
Hi,
I have had this issue twice this week, not sure why but both to do with Magenta on both machines and both times the magenta had leaked by a considerable amount, Ive taken the laser out and cleaned it, tried different drums, updated the firmware, dumped the DC and re entered values but still came up with the error, stick the old drum in and works fine apart from the PCQ, so last resort was to swap the drum chips over, works fine then, one thing i did notice, was that when I attempted to dump the DC and i pressed ok, restarted the Machine, it looked like the DC didnt clear, as all jam codes/error and other values were still in the machine, looking at the P print, none of the values had changed, so Ive ordered a DC controller, as I had this issue before and it turned out to be the DC, I will keep you updated as the part will be with me tomorrow.Comment
What an awfull machine by Canon, IRC2380 series was a great model, a few modifications & if could have been perfect.Let us eat, drink, and be merry, because tomorrow we may die!
Nicely and concisely said.....
Bottom line though in all the above... the mighty $$$....dollar.....$$$$.....
As it will always be said for time immeasurable -- "The love of money is the root of all evil"...Inauguration to the "AI cancel-culture" fraternity 1997...
•••••• •••[§]• |N | € | o | M | Δ | t | π | ¡ | x | •[§]••• ••••••Comment
This is a cheap colour printer, pulverized toner, cheaply designed. Don't try to compare it to 5000 or 5200 series. When a customer goes from a Irc3380 to one of these, they have been downgradedComment
Replacing the chip from old drum to new drum is a cheat - not recommended
check wee clips are on springs at front and rear of ext trans unit (one white, one black)
Clean laser and patch sensors
new drum
Do T1 up in Service mode and then open and close door.
Vac out entrance to hopper and ensure sensors are clean . (one at each side of hopper opening)
Failing that new Laser and Full HVT will normally resolve
CiaraComment
Changing the chip (the copper connector on the front) on the new drum to the one for the old drum will remove the error but may not fix the real issue
Sent from my SM-G925T using TapatalkComment
hi please don't change chip.you will come right now but only for abit.old problem will just come to new drum..for example.bk is light.u rep new drum but get err and u swop chip.will be fine for 3 or 4 days then after that new drum will become light.yes problem is laser.inside laser you must clean lens and poof problem will be sorted.Comment
