7095 quality wash out problem even after new coronas and laser units.
  • Simons
    • Jun 2008
    • 490
    [CQ] 7095 quality wash out problem even after new coronas and laser units.
    Has had a few different laser units. Some boards changed. On version 2 software now at 80.02 . Will check values in machine while running and see if laser power is good and other values too. Should make evident if laser is faulty. Anyone have a saga to share about this issue ?
  • Chameleon
    • Nov 2011
    • 200
    Re: 7095 quality wash out problem even after new coronas and laser units.
    I've seen that on NP6050's, ir5000's, ir105's, ir7105's and ir5570's. It usually has to do with coronas leaking voltage, especially the transfer corona. The pre-transfer or primary can leak and cause it too. Have you changed the HV unit or the transfer corona block? Take the transfer sep corona out and clean under the guideplate. There was a techpub on how to use a voltmeter to check everything on the drawer from the LFR bearings to the reg clutch and guideplate for shorts to ground.
    One last thing to try, increase the current to the transfer in service mode (Copier->adjust->TRN-1, TRN-2?)
    The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
    • canonbundy
      • Jun 2012
      • 607
      Why pray tell have you changed the Laser Units? Chamelion is correct in saying check/replace T/fer Sep & Main Corona Units but I will put up a big STOP sign at changing Values. How many prints has the Box done? Some times just a simple clean of the connectors of the Fixing Drawer Assy and the connectors at the rear of the machine with a cloth moistened with WD40 or RP7 can work wonders with the tarnished contacts especially on Units over 4M.
      • Rachid.Akli
        • Oct 2011
        • 595
        1- Start by cleaning your drum using CK-0429 pouder mixed with alcohol.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • Simons
          • Jun 2008
          • 490
          OK , Lasers were changed by another company. They had something from canon about there being some defective ones or ones needing a free upgrade at a repair center. The symptom has remained the same
          • godyng
            • Dec 2008
            • 40
            First change all the charger wire
            Second change the HVT PCB
            • Simons
              • Jun 2008
              • 490
              Drum is not very old at all , maybe a million. It has new corona assembly's. Has many millions on it. TP09 229.pdf shows the problem with laser unit . This results in light images, e110 and mirror images.
              • canonbundy
                • Jun 2012
                • 607
                Yeh, so do as I posted earlier and if the machine has done "many millions" then replaced the Dev Unit complete - The End!
                • Simons
                  • Jun 2008
                  • 490
                  Dev unit is in great condition. Its been replaced at some point.
                  • vigour
                    • Aug 2010
                    • 1038
                    Developer Clutch
                    • teckat
                      • 16083
                      note on Laser Exchange from y2009> this was only on a limited amount> + it needed to be thru a Canon Authorized Dealer-
                      LASER EXCHANGE.pdf
                      if i missed something>>>
                      u never stated if this issue is on Network Prints or Glass Copies or both
                      IF PRINTS ARE LIGHT and COPIES ARE FINE
                      >>The problem may be corrected in level 2 Service Mode > Copier > Option > User > PR-D-Se > from 4 (default) to 6.
                      instead of toe tapping with swapping parts>>
                      u need to discover where this issue either starts > or during > the copy process-
                      1-did u check the Laser Dust Proof Glass-To find the dust-proof glass you must pull out the primary corona unit. is it there ?/did u remove & inspect>clean
                      2-did u check the transferred image on drum surface -
                      CHECK DRUM SURFACE POTENTIALS
                      The measured and target values (VL1M and VL1T) (VDM and VDT) in DPOT, SERVICE MODE>COPIER>DPOT, should be relatively close in value.
                      When the measured value of VDM (VOLTAGE DRUM/DARK) is close to the value of VL1M (VOLTAGE LIGHT) the SCANNER LASER AND BLANK LAMPS should be investigated because the primary voltage is not being dissipated by light.
                      3-Check visually to make sure that blanking lamps are coming on. Replace LED ARRAY Unit if needed. = FH7-3395-020
                      4-Check the the laser shutter. When the shutter is not open fully, the VL1 value will rise. Bent actuator may be the cause.
                      4-Developer Clutch ?
                      Start a copy job of 25 copies. After the start of the copy job enter service mode under display select DPOT and check VLT and VLM. VLT (voltage light target) should be around 75 and VLM(voltage light measured) should also be near 75. With this problem VLM may read around 200, this means there is not enough discharge of the drum.
                      This usually means laser unit issue
